Old 08-30-2016, 04:16 AM   #1
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Engine vibrates unevenly and the exhaust pulsates.
The car sounds sick like it is misfiring and the exhaust is pulsing. Engine vibrates! engine has 180 000 + k's. Any idea what it could be?
Old 08-30-2016, 04:39 PM   #2
junorico24
junorico24's Avatar
Is it possible to put a 2013 engine in a 07 Yaris?
Old 08-30-2016, 06:43 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Might be an intake leak. Are you getting any trouble codes?
Old 08-30-2016, 07:14 PM   #4
junorico24
junorico24's Avatar
AH, ok so is the a gasket there or i need to tighten the bolts?
Old 08-30-2016, 10:22 PM   #5
SirDigby
Drives: 2007 yaris 3 door
check engine codes. ever change your sparkplugs? clean air flow sensor? CHECK ENGINE CODES!
yes, the 13 will fit in the 07
Old 08-31-2016, 12:00 AM   #6
junorico24
junorico24's Avatar
Originally Posted by SirDigby View Post
check engine codes. ever change your spark plugs? clean air flow sensor? CHECK ENGINE CODES!
I sold my Yaris to my bro he came home and told me there's something wrong with the YARI.
We changed the spark plug and cleaned the MAF. When he gets home today we will clean the TB and tighten the intake.Maybe there's an air leak somewhere.
I don't have a code reader but check engine light did come on.
Old 08-31-2016, 02:29 AM   #7
yariseggvvti
Drives: Yaris Hatchieback
replace engine mounts. left, right and lower.
yariseggvvti is offline   Reply With Quote
Old 08-31-2016, 02:30 AM   #8
junorico24
junorico24's Avatar
Fixed turns out cylinder 2 coil pack was bad.
NOTE; always use OEM Denso toyota pack.
Old 08-31-2016, 10:38 PM   #9
SirDigby
yeah. and always use NGK or Denso spark plugs....
