09-19-2016, 03:23 PM | #1 |
Jesper M
Drives: Toyota Yaris Verso 1.3 Join Date: Aug 2016
Direct battery connection - how can it be done?
Hi Toyota Yaris forumers,
I have a possibly simple question that I hope one of you may know about ... As it is I would like to connect a cooling box directly to my Yaris Verso's battery (will make sure a low bat circuitry protects the battery), however, would appreciate an advice on how a cable can suitably be guided from the battery into the cabin in a simple and preferably non destructive way (i.e. very preferably no drilling). Might one of you have a suggestion for a simple and straightforward way of doing this? Thanks for any help Jesper |
09-19-2016, 05:39 PM | #2 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
Why dont you want a battery heater living so far north?
09-20-2016, 02:47 AM | #3 |
Jesper M
Well, that's not what I need & I don't think it's necessary - the car appears to always start even when the battery is very low on energy (which would be the case if the battery is very cold) ...
Jesper |
09-20-2016, 05:50 AM | #4 |
Can you describe again in other words what you (adwant to do because I don't understand.
09-20-2016, 08:39 AM | #5 | |
09-21-2016, 02:02 AM | #6 | |
Jesper M
Yes you are exactly right - and I would like to mount a cable directly on the battery and lead it into the cabin preferably without drilling any holes ... might you have any ideas? Cheers, Jesper |
09-21-2016, 02:13 AM | #7 |
Jesper M
Hmmm... guessing that the "ceiling - light" sockets somehow could be used as they are not switched on/off when the car otherwise is switched off ... But I don't know what the power rating of the wires going to these lights are ... Anyone knows?
Cheers, Jesper |
09-21-2016, 08:36 AM | #8 |
Somewhere there has got to be a rubber grommet in your firewall through which wiring is already fed. Just matter of finding it and fishing your wiring through it.
09-21-2016, 10:44 AM | #9 |
RIGHT BEHIND THE COMPUTER on the right hand side of the firewall is good...on my 09.
09-21-2016, 01:36 PM | #10 |
Jesper M
@bronsin & WeeYari ... Thanks for your suggestions. I will look after the grommet and in general holes in the firewall. Mine is a 1999/2000 so it may not be identical to a 09 or 06 but will see what looks feasible.
Cheers, Jesper |
Similar Threads | ||||
Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
Remote for remote starter draining its own battery. | bad | DIY / Maintenance / Service | 4 | 11-01-2015 01:00 PM |
Battery keeps going dead | Outdoorsman | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 09-09-2013 04:43 PM |
Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
