Old 02-18-2017, 05:30 AM   #1
rabbito
rabbito's Avatar
what spark plugs are you using with your current engine setting
i am using ngk iridium spark plug with minor E85 tuned engine..some are saying how we should use colder spark plugs for turbo or tuned engine etc.
higher octane = colder plugs? opinion on spark plugs?
Sent from my SM-N920C using Tapatalk
Cosmetic: Toyota red emblem
Old 02-18-2017, 07:52 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
Stock came with NGK. I put Denso Iridium in.
Old 02-18-2017, 01:25 PM   #3
SirDigby
Drives: 2007 yaris 3 door
no. higher compression/cylinder pressure= colder plugs.
I installed a new set of OEM Toyota plugs when I bought my car. plugs don't really have any performance gains until you change something drastically in the engine. if you have a distributor, silver plugs have the least resistance and can give you slightly quicker spark timing, but in a DIS system the computer compensates for the built in resistance of platinum/iridium; if, however, silver is installed it will create a detonation issue because of the lack of resistance.
the advantage comes with a multi-spark system. the only one I have found is okada projects coils, but they are like $900 (but I've heard they work very well)
http://www.okadaprojects.com/usa/products.htm
http://www.ebay.com/itm/NEW-OKADA-PR...xVAIBT&vxp=mtr
Old 02-18-2017, 02:02 PM   #4
rabbito
rabbito's Avatar
thank you for the wonderful right up 👍👍
right now i recently got piggyback ecu that tuned E85, ignition and injection(1jz) to the fullest without any internals hitting 7,000rpm..i am flying(only stage 1 point of view) right now haha..one morning when i started my car, i hear slight sewing machine sound..a slight tick that got me a little worried...thats when i read about the colder plugs on E85 with iginition timing thing..
stage 1 meaning for other readers: every bolt on external; intake, header, pulley etc..
Old 02-21-2017, 10:53 PM   #5
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
T.M. Works also have a lot of ignition products and what I like about them is that upgrades can go in stages. But of course if you are force inducted and want to go for the best then just go Okada!
http://tmworks-web.jp/pages/products_eng.htm
Fluxtasy is offline   Reply With Quote
How to change spark plugs mitsua General Yaris / Vitz Discussion 4 08-14-2015 09:59 AM
Changed Spark Plugs MyzticZ3r0 DIY / Maintenance / Service 4 11-14-2014 12:58 AM
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
spark plugs walt101786 DIY / Maintenance / Service 0 09-24-2011 05:25 AM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 08:38 PM
