![]() ![]() Drives: 2013 Hybrid 1.5L T4 Join Date: Jan 2011
Yaris hybrid '13 when doing 60 revs high - expect it to switch gear
I just purchased a '13 hybrid yaris. And had a friend of mine which is a car guy more than i am, test drive it for me. The only thing he complained about is when doing 60 he kind of expected it to 'relax' at some point by upping another gear. Yet it kept kind of high revs. Seeing there's no rev meter in the cluster onr cannot know for sure how much revs it's doing. Also he said that gear change couldnt be felt/noticed much, but the seller said its because its a cvt tranny...so thia makes it even more difficult to distinguish gear changes.
Can anyone owning a hybrid clear this out for us if they experience same behaviour, or its just this car? Thanks everyone for this fabulous gem of a forum in here. Ian |
Radical Dreamer
Drives: spiritedly. Join Date: May 2016
That's normal for a CVT, as the transmission is designed to keep the engine at its most efficient rpm. These transmissions don't have any gears, instead you have pulleys and a belt. As the speed changes, so does the pulley size, which gives you an infinite set of gear ratios between the pulleys smallest and largest diameter.
I'm no expert on CVTs, this is the general info that I know. Good luck with the purchase! ![]()
Enjoy Family Car Sports |
#3 | |
![]() Quote:
There are no belts or pulleys in a Toyota Hybrid system. The gear ratio is determined by the speed and direction of rotation of the two electric motors and the internal combustion engine. There is nothing to ever wear out or fail and it is completely variable.
#5 | |
It all depends on load. You'd need to hook up a scan tool that can read RPM to see what it's actually revving. I've driven Prius, Highlander Hybrid, RAV4 Hybrid and Lexus CT200h. They all rev high when accelerating up to highway speed. But if you coast or let off the throttle the RPM basically come down to an idle depending on how fast your going. If you're below a certain speed the engine with stop running entirely.
#7 | |
Thanks again guys! |
I'd guess it's probably around 3000@ 100km/h, 60mph
#9 | |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Gear fault on a 2009 manual toyota yaris please help! | Gretch2689 | UK | 1 | 03-06-2014 01:41 PM |
i'm back and with a yaris hybrid !! | 746watts | New YARIS Purchase Forum | 10 | 02-21-2014 03:26 PM |
Consumer Reports not too pleased with Yaris | Befuddled | General Yaris / Vitz Discussion | 132 | 02-28-2011 02:57 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
