Old 05-24-2017, 09:51 PM   #1
RyanEchoRS
Drives: 2004 Echo RS
Will a Yaris Supercharger fit on an Echo?
I'm curious about this because I saw a used Blitz supercharger for a Yaris. Would it fit on an Echo without significant changes?
RyanEchoRS is offline   Reply With Quote
Old 05-27-2017, 01:08 AM   #2
SirDigby
Drives: 2007 yaris 3 door
it's the same engine. i would think it would fit the same...
Old 05-27-2017, 10:39 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
The compressor and plenum will fit. The intake tube is application specific because the Echo has a 3-bolt throttle body, the Yaris has a 4-bolt. There are varying reports of the alternator bracket having 2 different designs, so you'd need to look around the forums a bit more to get a definite answer.
Old 05-27-2017, 09:25 PM   #4
johnny_vitz
Drives: 2005 Toyota Echo
The echo 1NZ has a different upper oil pan then the yaris does...I found that out when trying to order an engine. It changes the alternator mounting points so I would have to think the bracket for the S/C bits wouldn't work on the echo
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Be honest, if you could go back in time and do it again..... bentjazz General Yaris / Vitz Discussion 127 02-25-2013 03:11 AM
05 Echo RS or 08 Yaris RS? tawheed General Yaris / Vitz Discussion 18 01-06-2011 03:27 PM
