Old 06-15-2016, 02:30 PM   #19
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
Originally Posted by junorico24 View Post
Too much work, parts and DIY know how to get it right. The prius piston swap seems easier.
Takes less DIY know how, than a piston swap, and still runs on 83 gas. Not to mention more power. Super easy and can be done in a Saturday.
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed.
Future: Turbo.
brushforhire is offline   Reply With Quote
Old 06-15-2016, 02:50 PM   #20
brushforhire
Will it be as good as mazda3 sp20 or sp25?
If the only reason to do any mod it be better than some other car, then why bother modding any car. We do it for the love of it. My Yaris was a blast to drive, and it was unique, and mine.
Buying some car that any can buy, isn't any fun for me.
Future: Turbo.
Old 06-16-2016, 01:41 AM   #21
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
I agree.
Old 06-16-2016, 05:17 AM   #22
darkangel86
Drives: 2007 silver yaris 3 door
Yes Bro!!! We manage to wangle ourselves in everywhere!!
But as far as I figured, the gearbox will be the same, but as you say, let's wait for someone who knows for sure to help out on that. Don't want to be going around talking
I also thought about the 1.5 swap, but for real bro, I'm seriously into doing some massive turbo'ing on the car at some point, so in the long run the 1.5 won't cut it when it comes to power output.
If I get the parts I sure will need the help!! so I'm all for the offered help! haha we'll make a jol of it like proud Suid Afrikaners!
darkangel86 is offline   Reply With Quote
Old 07-01-2016, 09:49 PM   #23
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This is why you can't use the Corolla/Matrix/Vibe engine bracket. All bolt holes for the engine block are aligned. Corolla P/N 12315-37030. The xD is 12315-37040.
Old 09-06-2016, 06:58 PM   #24
Yaris_Mac
Drives: Gas saver
Hi,
Can I use the stock 2008 Yaris 5 speed manual transmission with the 2ZR-FE?
My car is stock except for:
Fidanza Flywheel (8.64 lbs)
NST crank pulley
McLeod Stage 1 clutch
K&N OE filter box...
...That I installed this weekend.
Yaris_Mac is offline   Reply With Quote
Old 04-06-2017, 11:44 PM   #25
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Originally Posted by Yaris_Mac View Post
Hi,
NST crank pulley
Yes you can.
Old 04-07-2017, 09:56 AM   #26
CrankyOldMan
Yes, you can use the gearbox but you need the xD mounts (all six pieces) and the xD shift cables. The flywheel won't work (6-bolt on the Yaris vs 8-bolt on the xD) but the pressure plate and friction disc should be fine.
Old 06-07-2017, 11:25 PM   #27
LittleblueechofromOZ
Drives: 2005 Toyota Echo
Will this be much different in an echo (04)? would the mounts be the same?
LittleblueechofromOZ is offline   Reply With Quote
Old 06-11-2017, 12:16 PM   #28
CrankyOldMan
As far as I know, this swap is not compatible with the Echo frame. The only reason it works with the Yaris is that the xD has the exact same lower half of the unibody as the Yaris.
That said, don't let me stop you from doing more research and finding out!
Old 09-01-2017, 09:16 AM   #29
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
so will the highest ouput 2ZR fit in the yaris? aka the 148 HP one? cause like im about to ditch my 1nzfe as much as I love it, the greddy turbocharger on stock internals apparently makes 200Hp.
DarkShadowFox is offline   Reply With Quote
Old 09-19-2017, 03:01 PM   #30
coolguyndc
Drives: 2012 Yaris LE
Is it compatible with 3rd gen Yaris too?
coolguyndc is offline   Reply With Quote
Old 10-04-2017, 01:07 PM   #31
cerberii
Drives: 2005 Yaris
please post pics of the actual swap, putting the motor in, etc, excellent build thread, look forward to seeing how it actually looks with this motor inside it! Is the fuel pump enough not to starve this motor? Have you worn through axleshafts quicker?
cerberii is offline   Reply With Quote
Old 10-04-2017, 01:14 PM   #32
CrankyOldMan
All of the 2ZRs that we are aware of will fit, since they have the same mounting points. The difference in rated hp has more to do with the intake and exhaust setup on the specific vehicle, and possibly the tune in the ECU. I have looked at the Corolla turbo package from TKC and it seems like it could be modified to fit our engine bay. The base kit there is rated for 220 bhp.
As far as anyone can tell, yes. The chassis is the same on all of the USDM variants. We've had different results with the engine mounts on specific vehicles, so your mileage may vary. =)
Originally Posted by cerberii View Post
please post pics of the actual swap, putting the motor in, etc, excellent build thread, look forward to seeing how it actually looks with this motor inside it! Did you take the front clip off or put the motor in from underneath?
There's a few threads out here already. Check out brushforhire's, ArmstrongRacing's, TMontague's and my thread for details. It's really pretty straightforward, so not a lot of pictures have been taken during the physical installation. I absolutely recommend pulling the front clip to do the swap, as well as partially dropping the sub-frame. It looks like a stock motor in the engine bay as well, so not a lot of pictures of that either. =D
Old 10-04-2017, 01:15 PM   #33
DarkShadowFox
can we get pics tho .w.
Sent from my LG-H918 using Tapatalk
Old 10-04-2017, 02:34 PM   #34
tmontague
tmontague's Avatar
Of what? As stated there are plenty of archived pics on the forum regarding the swap
Old 10-04-2017, 02:35 PM   #35
DarkShadowFox
we wanna see your finished product and stuff :D
Old 10-04-2017, 02:45 PM   #36
tmontague
tmontague's Avatar
I'll see if I can find anything on my phone. Other than that just my signature pic is all I have
The 2zr-fe engine swap guide ArmstrongRacing Performance Modifications 416 08-14-2023 03:14 PM
engine swap yaris9876 DIY / Maintenance / Service 12 12-26-2013 10:27 PM
engine swap djhuddy2442 Performance Modifications 6 04-11-2013 01:05 AM
Engine Swap Nutzoids Performance Modifications 42 10-01-2007 06:20 PM
if i am thinking about an engine swap - from 1.3 to 1.5 - please help ASHRAF Performance Modifications 15 01-03-2007 01:40 PM
