Old 04-18-2016, 10:15 AM   #1
speccyalex
Alex
Drives: Toyota Yaris T3
Exclamation Toyota Yaris Amp Installation - Battery Issue
Hi guys, I'm relatively new to this forum so I'm still finding my feet!
I've installed an amplifier to my Toyota Yaris 2010 with the original HU (using a wiring kit). I installed the remote wire by splicing off the 12v ignition wire to the head unit and connected it to the amp remote section.
When I connect the fused power wire from the car battery (+) to the amplifier (B+), not only does the amp fail to turn on but the central locking via the remote fob stops working. If I remote the wire from the battery (+), the remote locking functions again.
Any ideas why this could be happening?
Thanks in advance!
speccyalex is offline   Reply With Quote
Old 10-02-2017, 03:59 AM   #2
ibadtaylor
Drives: Yaris 2012
Hi.. How do you find the wire cable for the Remote, is there blue cable or in your OEM head unit?
I have trouble when I installed subwoofer, but I can find in my OEM head unit to REM on my subwoofer
Sent from my E6653 using Tapatalk
ibadtaylor is offline   Reply With Quote
Old 10-02-2017, 06:26 AM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
You plug the remote to the power antenna.
Sent from my SM-G930W8 using Tapatalk
Tags
amp, battery, installation, issues, subwoofer
