06-07-2020, 07:11 PM | #1 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Throttle Body Gasket Screen?
For those in the know, is there expected to be any adverse effects if I am to remove the little 1/2 screen that is moulded into the throttle body o-ring? I am solely interested in doing this to improve my atomized water/methanol delivery into the throttle body. Any obstruction whatsoever starts to bring the water methanol mixture out of suspension. I am also toying with 2 ideas: 1) install a throttle body spacer and spray directly into the manifold or 2) direct port injection - one 30cc/min nozzle in each runner, close to the head.
06-07-2020, 09:04 PM | #2 |
Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I thought it's only there so that the throttle flap don't go over past parallel? Not sure, I'm probably wrong. Maybe you can remove the first layer with the screen? Actually I might do that, since I'm gonna go with the 1ZZ TB for now since I don't have the $$$ for the engine swap yet.
06-08-2020, 01:04 AM | #3 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
I believe those honeycombs are there to straighten out the air or something like that so that the MAF sensor has an accurate reading. Not 100% sure on that tho. But I think that's also the same reason why K&N had some kind of flap in their intake pipe.
06-08-2020, 06:05 AM | #4 | |
06-08-2020, 06:07 AM | #5 |
I believe you are correct. Hopefully removing it won't cause erroneous readings.
06-09-2020, 10:12 AM | #6 | |
2ZR swap. DO IT! Ask how!
https://www.justanswer.com/toyota/4m...-throttle.html https://www.spyderchat.com/threads/s...purpose.71002/ It's there for a reason, even if it's not publicly visible. =) |
06-09-2020, 09:15 PM | #7 | |
Similar Threads | ||||
Successful 1ZZ Throttle Body Swap | rabbito | Performance Modifications | 30 | 11-04-2022 09:05 PM |
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 08:52 PM |
