is that possible? yes I know it is.
What part will I need to buy to do that? give names and a rough estimate, and lets say in roughly 2 years from now when my automatic goes bad. -- Blen
http://www.360voice.com/tag/noobblenjar ![]() My Car http://www.yarisworld.com/forums/showthread.php?t=4245 My DJ www.PainlessWolf.com |
Look slow, go fast
Drives: 2007 Yaris Liftback 5 spd Join Date: May 2007
Changing transmissions?
Don't bother... The transmission, modifications, installation, impracticality and the computers that control moderns cars would render the retrofit so expensive and difficult, that you may as well get a new (or used) 5 speed Yaris. Making it a semi-automatic transmission would be easier, but still a feat
Daily Driver:
Toyota Yaris Hatchback, 5spd. Go-fast: 1995 Chevrolet k1500 extended cab Blown 396 smallblock 797hp @6500RPM looks stock, but burns riced-out imports daily. |
what's a semi automatic?
-- Blen
Where has speed limit "none"?
I wanna go there =D -- Blen
Look slow, go fast
There are many names for it... It's basically an automatic, except you tell it when to shift (with paddle shifters or the like).
Daily Driver:
![]() ![]() Drives: Camry LE/Yaris Hatch 5spd Join Date: Jul 2006
Yes their is a semi automatic for the yaris. I believe it comes with the 1.3 and 1.4 liter engines. I am positive on the 1.3 because I have seen it before, in fact here is the link. The picture is kind of hard to see but it's their. As for being swappable don't know, but will find out what tranny it is soon, and if it is possible..
|.....Overnight.........................| || |........Parts From Japan.............||'|";,__ |_..._...____________======||_|_|....,,] "(@)'(@)''''''''''''''''''''''''*|(@)(@)****** **"( @) |
![]() Drives: 07 Yaris soon Join Date: Apr 2007
With a little more research that it the Toyota MMT Transmission. The only tranny I know that will fit with our motor is the c160 ae11 black top with the 6spd. Still researching though.!!
Tired of the Stars!
Out of all the cars I've ever had, only had to rebuild one automatic (& the car had been sitting for 2 years prior to the rebuild). However... I've spent a small fortune on clutch/pressure plate/t-o bearings for the manuals I've had.
![]() Drives: Yaris 1.3 MMT SOL Join Date: Jun 2007
speed limit "none"?
![]() Drives: 07 Yaris LB Join Date: Jun 2007
Not worth the time and money...
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal | hasher22 | DIY / Maintenance / Service | 88 | 03-06-2014 06:40 AM |
Manual Yaris performance info? | SimmZ | General Yaris / Vitz Discussion | 22 | 10-27-2009 09:27 AM |
The Toyota Authorized Repair Manual. | LoudYar | General Yaris / Vitz Discussion | 3 | 03-29-2007 12:20 AM |
Manual vs. Automatic ?? | YarisBlazer | General Yaris / Vitz Discussion | 12 | 08-13-2006 07:14 PM |
Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
