Old 03-16-2022, 06:33 PM   #1
Neinris
Drives: 08 Yaris 3 Door Hatchback
ECU Reflash service…
Just want to share this to everyone if it hasn’t been posted…
https://christaylorracing.com/produc...a-toyota-yaris
Increases the REV up to 7400RPM.
Neinris is offline   Reply With Quote
Old 03-18-2022, 01:12 AM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Intriguing.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 03-20-2022, 12:55 AM   #3
IndestructibleYaris
Only works for 2007 yaris as he specifies that you cannot have a yaris equipped with the factory alarm
IndestructibleYaris is offline   Reply With Quote
Old 03-20-2022, 07:18 PM   #4
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Years don't matter issue is the factory alarm due to key-ecu mismatch, it was my car he developed the tune on. Tune works great on mildly modified engines.
It works on many different years. The factory alarm issue is a bigger problem because of the key and column and ECU are tied to each other and cannot be swapped with another part.
2014 BSpec Divisional Champion
Old 03-20-2022, 11:53 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Would it work on a 3rd gen?
2014 NCP131 5 Speed
Old 03-21-2022, 01:35 PM   #6
remcafee
so do you tell him what mods have been done and he will tune the ecu accordingly? or is it just a preset for all kindsof setups? how about drivability and emmisions? im kinda interested
Old 03-21-2022, 07:33 PM   #7
Neinris
I can’t speak for the company, I’m just sharing my find. Xnamerxx might be able to answer your questions. I’m more interested to know if they can also reflash the 2ZR ECUs. I’ll message them once I find a donor car.
Old 03-23-2022, 06:06 PM   #8
xnamerxx
0-60 in slow
xnamerxx's Avatar
I don't know if they've tried a 3rd gen but I know he had some ECU's so its possible.
There is some customization that can be done, but its a mailorder tune so there are some things that need to be done via dyno because it would be unsafe for the engine.
Change ECU No DTC codes, With Crank and Fuel Pressure not starting/no Spark tatlogis DIY / Maintenance / Service 0 08-13-2021 12:24 PM
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 09:40 AM
MWR AEM EMS 4 P&P ECU tmontague Performance Modifications 3 02-09-2020 08:07 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 01:50 AM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 09:56 AM
