04-19-2022, 12:13 PM | #1 |
Drives: yaris Join Date: Nov 2018
Lightweight crank pulleys?
Looking to maybe put some lightweight pulley on my Yaris but I'm a bit hesitant about reliability since I drive this car over 40k a year.
There doesn't seem to be many options for the 1nz, so far my options are a vividracing or AROSPEED on ebay. https://www.vividracing.com/nonstopt...151673703.html Has anyone had experience with these parts and the quality? I'm also worried about the stock pulley being a harmonic balancer and potentially putting wear on the crankshaft if I remove that balancer. If so, I am debating if this is more of a "race car" mod rather than long-term reliability. |
04-19-2022, 02:10 PM | #2 |
Drives: Yaris T sport TRD turbo Join Date: Aug 2017
In my experience it didn't do much, better invest in lightweight flywheel
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
04-20-2022, 12:34 AM | #3 |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
I have the NST crank pulley on my car, its definitely more responsive and heel-toe downshifting is a breeze.
The downside is that there is less rotating inertia so you have to slip the clutch a bit more to get going smoothly, not a big deal if you're a competent manual driver.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's |
04-21-2022, 09:37 PM | #4 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
i would recommend not doing light weight crank pulleys, they dont have any harmonic dampening, so you will ruin your crankshaft bearings prematurely
04-21-2022, 10:41 PM | #5 |
Gen 3 > Gen 2
1NZ-FEs aren't internally balanced?
05-25-2022, 07:21 AM | #6 |
Drives: 04 3dr HB and 04 5dr RS Join Date: Mar 2018
There is no harmonic balancing on the Echo, the engine must be internally balanced.
05-25-2022, 07:53 PM | #7 |
Gen 3 > Gen 2
Yari' use the same crank pulley as the Echo despite them only using one accessory belt.
02-25-2023, 12:35 PM | #8 |
Drives: 2007 yaris 3 door Join Date: Sep 2015
NST crank works okay for N/A. they will break under pressure. (+5 years)
NST water pump pully DOES NOT work. the belt eats through the thin aluminum (6months) NST alt pully works fine. you save 2g or whatever. not worth paying for IMO. |
02-25-2023, 07:43 PM | #9 | |
Drives: NCP90 TRD Yaris Manual Join Date: Oct 2022
Similar Threads | ||||
WTB: MI lightweight crank pulley | cwitte | Willing to Buy by private party | 2 | 06-24-2015 10:48 PM |
DC header, AEM cai and MI lightweight crank pulley install | aspro | Performance Modifications | 7 | 09-02-2014 06:57 AM |
Lightweight Crank Pulley | axiom | Performance Modifications | 16 | 09-01-2014 09:29 PM |
NST crank pulleys 15% off | cali yaris | Micro Image | 0 | 08-19-2010 05:28 PM |
Crank pulley's for Yaris? | ToTo | Performance Modifications | 12 | 03-04-2007 04:42 AM |
