Old 09-27-2022, 03:12 PM   #19
remcafee
you should cut the bump stops, the instruction manual on the tein springs say to cut bump stops 1/2 an inch
Old 09-27-2022, 03:17 PM   #20
remcafee
Originally Posted by Neinris View Post
I did not trim the bump stops, it think I still have 3-4 inches of travel left. I tested her out on the road where there’s a lot of bumps and pits, nothing too extreme. What a huge difference the new struts make. She used to feel like she was bottoming out when I used to hit those same bumps and pits, shaking the whole chassis, but now she feels like a regular ride. I’m really happy with them.
if you cut the bumpstops you might get the front down a little lower, more than likely you are riding on the bump stops right now because they are stock height and lowered springs, it will also limit the length of strut rod travel so you are not getting the full potential of that struts performance because it cant "compress" as it was designed to do
Old 09-27-2022, 08:36 PM   #21
Neinris
Oh... Thanks! I didn't know that... I'll see if I have time to mess with her this weekend.
I ordered a pair of adjustable sway bar links, 300-360mm, but they're meant for Hondas.
https://www.ebay.com/itm/18476889220...0d22%7Ciid%3A1
They have 10mm end bolts, but I talked to the seller, and they're supposedly including the adaptors for 12mm. Like what's on these other pair.
https://www.ebay.com/itm/13337489990...0d22%7Ciid%3A1
Hopefully they work. I have a clunking noise, even before I replaced the struts, I'm hoping it's just from bad sway bar links, but I'm afraid it might be from a worn sway bar bushing.
Old 09-28-2022, 03:31 PM   #22
remcafee
hows the control arms? check the back bolt, its common they break off inside the subframe
Old 09-28-2022, 06:13 PM   #23
Neinris
Sorry I didn’t mean to hijack this discussion. The lower control arm back bolts are fine. I know because I replaced the bushings to the lower control arms just a little over a year ago. And I had the clunking issues then already. I’ve inspected the sway bar bushings and they seemed fine, but can’t really count them out yet.
Back to trimming the bump stop, my ride doesn’t feel like I’m not even bottoming out. And I’ve tested before and after I went with the Bilstein B8, and the ride is a lot comfortable now. With the stock strut I was bottoming out, and the bump stop was stock length also. So I don’t know if I should trim or not.
Tags
daily driver, lowering springs, tein
Daily driver coilovers...asking for suggestions Yarflana Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-04-2013 10:38 PM
1990 Honda Accord Daily Driver wowitswil Cars for Sale by private party 2 04-01-2011 12:46 PM
Konig Feathers for Daily Driver??? MUSKOKA800 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 07-04-2010 07:05 PM
Lowering springs, turbo manifold, front driver headlight Moses Willing to Buy by private party 4 01-24-2010 03:00 AM
