Old 07-17-2023, 03:55 AM   #1
JStryker
Drives: 2007 Yaris 2-door
Motorkote in 2007 Yaris tranny?
I know it's only for standard trannys (not cvt) which I believe is in all 2007 Yaris.
Has anyone actually done this? Im about to vaccuum pump out the tranny (just completed the engine oil today) and wanted to see if anyone says to run like hell from this idea or if they've actually done it and recommend it.
There's slight transmission slip during the first 5min the car is driving then it's ok. Was wondering if this would help since I'm changing the trans oil.
Thanks
JStryker is offline   Reply With Quote
Old 07-17-2023, 07:18 AM   #2
ex-x-fire
I wouldn't put anything in an auto trans that isn't the correct fluid. You'll make it worse.
Old 07-19-2023, 02:25 AM   #3
sh0rtlife
a bandaid on an auto is always a bandaid.....more often than not you either kill it faster or slow its death...never have i seen anything "help"
Old 07-20-2023, 11:31 PM   #4
CrimsonEclipse
Drives: .
Thanks
Assuming it's an automatic transmission, and it's slipping when not warmed up, it's possible it just needs a fluid flush and new fluid.
Observe the condition of the old fluid.
If it smells burnt or is a brownish color, that's your main problem.
CrimsonEclipse is offline   Reply With Quote
motorkote transmission
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
