Old 03-10-2024, 09:07 PM   #1
alanwagen
Drives: 2015Yaris, Son's car, 10 Prius
Spark plug change hack.
No effing way but this works. Being a Toyota family, I changed the spark plugs on my son's 15 Yaris.
Due to age and heat, the clips on one the wire connectors on the coil pack broke. Apparently a very common thing.
Although redundant as the fiction alone holds the connector, I found this awesome hack to re-clip the connector back on.
You will thank me for this as I tried it and it works. All it takes is one medium cable tie. BTW, I used NGK Laser Iridiums which what was in it with no anti-seize as the threads are trivalent coated.
Watch the video.
https://youtu.be/gRvTbi7eNWk?si=4vRkaV0DNbbEDFXv
alanwagen is offline   Reply With Quote
1NRFE Spark Plug SC16HR11 Recommendation Pls mik23 DIY / Maintenance / Service 2 08-08-2021 11:49 AM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Tips for first spark plug change... nikonNUT DIY / Maintenance / Service 4 07-21-2014 05:59 PM
Attempting to change spark plugs caineroad DIY / Maintenance / Service 14 12-14-2012 02:23 AM
spark plug data Geoff Peace DIY / Maintenance / Service 5 09-29-2011 02:14 PM
