02-04-2009, 11:37 PM | #37 |
I used to have 1700 posts
update please
02-05-2009, 05:27 PM | #38 |
my stock afr sensor is moved away from my nitto midpipe to prevent it from reading crazy readings because of not having a cat. and i monitor the readings through my blitz r-vit and i took a look at it last night. it was reading 14 all the time and i my eyes immediately exploded but then i remembered i moved my sensor away from the pipe with a spacer.
anyways the point is i have been getting readings of 14.such and such for months and the ecu has never set a code saying its running lean |
02-05-2009, 09:00 PM | #39 |
Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
If it isn't raining too hard tomorrow, I'll see about routing the wideband harness through the firewall. I was going to clamp it to the end of my tailpipe to take a reading but remembered that on the automatic, the S/C does not engage in Park or Neutral so I'd only be reading NA operation.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
03-15-2009, 12:21 AM | #40 |
I finally got my vacuum/boost gauge and wideband a/f gauges installed and working. I really don't see a lean condition according to the wideband until I go into DFCO. According to the Autometer paperwork, I'm spending most of my time in a stoichiometric range.
Sometimes after WOT and releasing the throttle, the a/f mixture will briefly go rich. Perhaps there has never been a problem. This video has been cross-posted in another thread. You won't want to watch it again. http://www.youtube.com/watch?v=05RZSyraA5Y
03-15-2009, 12:27 PM | #41 | |
There's been all kinds of debate on this thread about whether the further back you have the wideband sensor affects the reading or whether it affects the lag time between throttle and the reading. Seeing as how the dyno guy read from my tailpipe, where I have the sensor now is fine by me. What I don't get is that from the a/f readings I got before the S/C, I was actually running a little rich during WOT. The S/C puts me right in the middle now.
03-15-2009, 06:47 PM | #42 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
03-15-2009, 07:25 PM | #43 |
correctumundo^
03-15-2009, 09:51 PM | #44 | |
03-16-2009, 12:03 PM | #45 |
Break'em off some.
I just watched the Youtube video. It looks too lean under boost, unless the timing has been retarded by the SC adjustment box (which could be the case). The first cat is not falsifying your AFR readings much. Clearly your wideband is very close to accurate because you are seeing 14.6 AFR during cruise.
Only way to tell for sure would be to datalog the timing, or get an EGT gauge, or both. Either way, the car would benefit from a tune, probably in the neighborhood of 15-20 HP. |
03-16-2009, 12:06 PM | #46 |
Really? So the dyno guy was correct? Where would one find the optimum a/f readings for engines under boost?
03-16-2009, 12:26 PM | #47 | |
Break'em off some.
You can run a lean AFR, with retarted timing, and get acceptable EGT values. You can run a richer AFR, with advanced timing and get the same acceptable EGT values. The proper AFR for a forced induction car is debateable, but generally in the 11:1 -12:1 range is acceptable depending on type of forced induction and boost level. I don't think blitz would send you out into the world with a tune that will pop the motor, but just be aware, the tune is far from its full potential. |
03-16-2009, 12:28 PM | #48 | |
Break'em off some.
We have been over what the instructions say. His setup is not optimal, but in this case it is fine. As you can see in the video, his wideband shows 14.6-14.8 AFR in closed loop conditions which we know is accurate. It is showing high 13s low 14s under boost. While this may not be exactly accurate, the cat will not change the readings by a 2 full points. |
03-16-2009, 12:29 PM | #49 |
Break'em off some.
03-16-2009, 12:33 PM | #50 |
03-16-2009, 12:35 PM | #51 |
Does that mean that the first cat is oxidizing, or whatever a cat does, the exhaust mixture to lower the amount of unburnt fuel thereby raising the a/f mixture?
03-16-2009, 12:38 PM | #52 |
Break'em off some.
Yes, but the cat does the same thing all the time. Your AFR is accurate while cruising. We have to assume it is close to accurate under boost conditions.
03-16-2009, 12:40 PM | #53 |
Ok. I was planning to run the SpeedVentures Streets of Willow on April 10 where I expect prolonged WOT operation and lots of boosting. Based on what you're telling me, that may not be a good idea until I get the AFR under control, right?
03-16-2009, 12:42 PM | #54 | |
Break'em off some.
I may be going to the April 10th day as well. |
Similar Threads | ||||
Lean Burn - Hydrogen Enrichment | GeneW | Fuel Economy Forum | 20 | 07-23-2010 02:59 PM |
New 2007 Paint Condition | Pavel Olavich | DIY / Maintenance / Service | 16 | 09-13-2009 04:14 PM |
WTB or free front bumper any condition in SOCal | Walter | Items for Sale by private party | 3 | 09-14-2007 12:56 AM |
