Old 09-12-2011, 06:46 PM   #1
Roth5150
Drives: Yaris 2003
Help with Loose Handbrake
Hi,
Could any of you tell me how easy is it to adjust the handbrake on a 2003 yaris. When I first pull up the handbrake it doesn’t hold the car sufficiently and if on a slight incline it begins to roll. I have to then pull the handbrake up to it’s highest possible point to have any effect. Is it possible to tighten the handbrake.
Thanks for any advice.
Roth
Roth5150 is offline   Reply With Quote
Old 09-13-2011, 04:30 PM   #2
bankrobber
Drives: 2007 Yaris Hatchback
You gotta take off rear drums and turn the little star looking wheel. Use a flat head screwdriver and turn both sides left wheel and right wheel evenly. Brake shoes may be worn out if handle moving that high also. You can find a DIY for adjusting brakes if you type that in search box that is how I learned lol.
Just remember turn 2-3 clicks at a time. I am not sure how to back if off if you get too tight brakes may drag
bankrobber is offline   Reply With Quote
Old 09-14-2011, 06:55 AM   #3
Vinceb
Drives: 2008 5 Speed Sedan
I think you just turn the wheel the opposite direction, it has an arm on it that you would lift to go back doesn't it?
I just had mine adjusted, holds the car after 2 clicks of pulling the e-brake lever.
Vinceb is offline   Reply With Quote
Old 09-14-2011, 10:56 AM   #4
Lil Abner
Drives: 2009 3dr LB Manual
Yeah, you don't have to take the wheels and drums off to adjust the shoes in the rear. There should be a rubber plug in the backside of the brake shield. Take that off, shine a flashlight in, and find the wheel to turn.
Handbrake Loose Roth5150 General Yaris / Vitz Discussion 1 09-12-2011 09:03 PM
how to break loose pulley bolt yaris9876 DIY / Maintenance / Service 10 05-16-2010 01:55 PM
Had my brakes done....now handbrake is harder to pull. captainm27 General Yaris / Vitz Discussion 7 05-10-2010 07:00 PM
Loose shifter knob dvspindler Cosmetic Modifications (Exterior/Interior) 7 08-06-2009 04:07 PM
Auto trans : Drive to Park + Handbrake : was not in park... Maxh91 General Yaris / Vitz Discussion 7 06-11-2009 06:37 PM
