12-07-2008, 11:55 AM | #1 |
Drives: 08 sedan auto Join Date: Nov 2008
Widest tires I can get for 15 stock wheelies
tire rack says 205/55/15
i've heard that wider tires means more stability on the road, and the wind won't push you around as much is it true? will it slow down my yaris? thanks! |
12-07-2008, 11:58 AM | #2 |
Drives: 2008 Yaris Sedan Join Date: Oct 2008
if you want to go wider on the stock 15s, i wouldn't recommend going wider than 195. you'll be stretching the tires too much.
12-07-2008, 02:00 PM | #3 |
rarer than JDM -1 of 1!
I'm on 195/55/15's on the same setup you are looking at. I would agree with Split that the difference b/w going 10mm wider is not as important as the safety factor of stretching tires, IMO.
I also live in a windy climate, so that was also my concern while upgrading my tires. The gearing will change, and the tires will feel less responsive torque-wise. But the grip should make up for it. |
12-07-2008, 02:37 PM | #4 |
Drives: 2014 White VITZ Join Date: May 2007
You can very safely install 205mm tyres on wheels from 5.5-7.0". No worries, mate. Recommended replacement size for the Yaris is indeed 205/55/15.
BTW, stretching a tyre means attempting to install a narrow tyre on a wide wheel; for example, 195mm tyres on 8" wheels. This kind of fitment is not recommended. |
12-07-2008, 04:40 PM | #5 | |
12-08-2008, 09:14 PM | #6 |
Similar Threads | ||||
Can I use stock tires on these 15" rims? | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 02-18-2009 07:11 AM |
Keep tires on stock wheels? | LtNoogie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 10-31-2008 10:00 PM |
FS Brand New Stock rims w/ Tires | FlintS | Items for Sale by private party | 10 | 09-24-2007 08:22 PM |
FS: 07 yaris RS stock rims n tires | thegame11 | Items for Sale by private party | 5 | 04-15-2007 01:25 PM |
FS: Stock tires on steelies | spkrman | Items for Sale by private party | 9 | 04-12-2007 06:45 PM |
