#1 |
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
Squealing brakes when cold?
I've noticed that my brakes tend to make a squealing noise when I first drive the car. It sounds like it's coming from the driver's side rear. Anyone else have this issue?
I'll most likely bring the car into the dealer so they can then tell me it's a normal wear-and-tear item and they won't fix it (how's that for optimism?).
Subcompact Culture: The Small car blog |
Beast
same here, just the 1st pulling out of the driveway, i think we discussed this already tho... Had to do with parking with the parking brakes and not the ebrake?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
#3 | |
I'll just bring it in.
#4 |
![]() ![]() Drives: Toyota Yaris Join Date: Nov 2008
Min has the same case, will bring it for servicing over the weekend.
Does your stop squealing after the first few brakes? |
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Sedan Join Date: Oct 2008
Whens the last time your rear brakes were cleaned and adjusted. Backing plate probaly just need to be lubricated and all the dust from the drums need to be cleaned out. Very common problem if it happens when cold and goes away when its hot. After you brake a few times the brakes get extremly hot and everything expands. WHen cold the gap between the pad and drum is greater. SO once they are adjusted properly the gap will be gone even when cold
#6 |
Back from the dead ...
Bringing the car in tomorrow to the dealer; we'll see what they say. I hope they don't give me the runaround about "brakes are a wear-and-tear item," so they won't fix the noise under warranty.
#7 |
for me they did a rear brake adjust and noise went away....
#8 |
I'll be sure and mention that some people I know just need the brakes adjusted.
#9 |
#10 |
Cool, thanks!
#11 |
FYI, Beaverton Toyota adjusted the brakes, no questions asked. That was easy.
#12 |
did they like the orange wheels and did they check for the new recall.....
#13 |
Haha--yes they liked the wheels. However, they did not check for the recall.
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
Mine does it only when it's cold and damp. Goes away by the time I'm backed out of the garage and down the driveway. Mine is due to a little rust buildup on the drums, goes away after the shoes clean off the rust; just normal for the weather conditions.
#15 |
![]() ![]() Drives: None. Join Date: Feb 2009
Sorry for the stupid question, do Yaris's have only drums in the rear or is there a 4 wheel disk option?
#16 |
At least in the U.S., drums are the only available rear brakes.
Reluctant upshift to 3rd while cold (auto trans) | pauljk | General Yaris / Vitz Discussion | 40 | 01-22-2011 06:04 AM |
Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
Brakes | Geelmeel | General Yaris / Vitz Discussion | 16 | 06-29-2007 07:58 PM |
Brakes question | MeggiemobileSFLA | DIY / Maintenance / Service | 23 | 03-16-2007 05:17 PM |
Changing drum brakes to discs? | eTiMaGo | Performance Modifications | 5 | 09-25-2006 04:17 PM |
