Old 08-04-2006, 07:31 PM   #1
SEaton
SEaton's Avatar
SUB/AMP w/factory head unit
Anyone know if I can wire a sub and amp up to the factory head unit? If so are there any complications or is it a pretty easy install?
2007 Liftback in 4-5 weeks!
SEaton is offline   Reply With Quote
Old 08-04-2006, 10:43 PM   #2
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
Simple intall, I have a how-to on yarisowners.com for an aftermarket HU but same would apply to a stock HU. Only diff being youll have to get a line output converter but other than that easy. What are you planning to run just for curiosity?
mikeukrainetz is offline   Reply With Quote
Old 08-04-2006, 11:51 PM   #3
SEaton
SEaton's Avatar
Sweet, a rockford 12". I just wasnt sure the stock HU would support running the amp/sub. Thanks Mike
Old 08-04-2006, 11:54 PM   #4
SEaton
SEaton's Avatar
I want to keep the stock deck because I dont have enough money for a new deck plus id rather keep my aux input in working condition
Old 08-05-2006, 12:31 AM   #5
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
If your amp has hi level inputs simply tap into the rear speaker wires and run them to the high level inputs on the amp. If you only have RCA (low lever inputs) you need to buy a simple output converter and again tap into the rear speaker wires then run RCA from the converter to the amp.
The only other thing you need to wire up is a remote on switch and the power/ground.
Old 08-05-2006, 02:38 PM   #6
mikeukrainetz
Thats precisely the reason to just wire into the stock harness or buy a Best Kits harness and just add the wires into the splice. Wiring into the rears means you have to pull apart the doors, splice into the wires and run to the rear and then you also have to run the remote on into the deck anyway. Its easier to hide the output converter in the dash.
Old 08-05-2006, 08:14 PM   #7
Chaad32
Chaad32's Avatar
Drives: 2007 Liftback
Does the output converter draw any of the power from the rear speakers if you hook it up to them, or does it just take the "signal" and convert it to line level for the amp?
2007 Liftback
Blazing Blue
Cold Weather, Convenience Package, Arm Rest,
Floor mats, Weathertech vent visors
Chaad32 is offline   Reply With Quote
Old 08-06-2006, 09:37 AM   #8
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
just takes the signal....
Old 08-13-2006, 09:02 PM   #9
DollaZo
DollaZo's Avatar
Drives: Toyota Yaris YRS
hey sup all
I have my stock HU and have put subs and two amps running in my Yaris. The best and safest option I find is to run an LC6 which is a Hi to Lo level converter. Its also a preamp, and uses RCA's as an output into my amps.
a remote bass control can be added onto the LC6 processor to adjust the bass accordingly
DollaZo is offline   Reply With Quote
Old 08-13-2006, 09:34 PM   #10
SEaton
SEaton's Avatar
cool, thanks for the info guys
installed head unit... punch In Car Entertainment + Electronics (audio / video / alarm) 16 06-29-2006 12:06 AM
human head in coffee beans wushumasterku Off-topic / Other Cars / Everything else Discussions 8 04-19-2006 11:39 PM
