Old 01-13-2009, 11:26 PM   #1
jmew0ng
Drives: Scion FRS
Problem with Projector Halo :(
Well I bought my projector(the depoautolight one) off of an ebay store, everything went great except only 3 out of 4 halo's work... my right front halo doesn't work =(
So I was wondering is it possible to just cut the wire connecting to the front left one so it'll look even, or will that completely drop the 2nd one as well?
jmew0ng is offline   Reply With Quote
Old 01-13-2009, 11:30 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Try it and find out you can always reconnect wires. I would assume it wouldn't affect it however considering if the LED it burnt out of the other light then it probably isn't completing the circuit.
Old 01-13-2009, 11:38 PM   #3
jmew0ng
Drives: Scion FRS
Yeah, I'll give that a shot in the morning then.. maybe you'll be able to see my car around phoenix! XD
Old 01-14-2009, 12:16 AM   #4
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Yep, you can try to remove the connection from the led lights, and try to reconnect them. Or rather, only try and connect the led and see if they are functional.
Old 01-14-2009, 12:44 AM   #5
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Don't be surprised with lights like those.
Old 01-14-2009, 06:06 AM   #6
PHXDEMON
PHXDEMON's Avatar
If you are ever downtown. I work in park central mall so you can find my car on the upper level in the parking lot in the northwest side
Old 01-15-2009, 09:08 AM   #7
GreenSpeed
Drives: '08 Yaris LB
I just picked up a pair as well off eBay and had the same issue. Simple fix was to go to Radio Shack. They have small white LED's that are the same size that you can solder in place of the old ones. Works great now.
GreenSpeed is offline   Reply With Quote
electrical problem with car need help badly!! Adriaan DIY / Maintenance / Service 20 05-07-2010 12:40 AM
Cruise Control pulsing problem. rg570lvr General Yaris / Vitz Discussion 14 12-07-2008 04:55 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
