Old 01-20-2009, 12:05 AM   #1
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
Tighten e-brake?
I was wondering if anyone could tell me an easy way to tighten up the e-brake on my 07 LB at the wheel instead of the cab???
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 01-20-2009, 12:07 AM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
http://www.etimago.com/yaris/repairm...37;20Brake.pdf
^^ That's the only way I know... HTH
Old 01-20-2009, 12:14 AM   #3
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
Search is thy friend someone just posted about this in the DYI
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 01-20-2009, 12:15 AM   #4
ztrack157
ztrack157's Avatar
http://www.yarisworld.com/forums/showthread.php?t=12333
Old 01-20-2009, 01:49 AM   #5
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Just a little note here: You should almost NEVER need to adjust the handbrake at the handle. That adjustment is only intended to compensate for wear and stretching of the handbrake cables, which is something that might be need to done once in 10 years. The adjustment you SHOULD be making is at the brake itself. Making the adjustment there affects not just the handbrake operation, but also actual braking.
Don't adjust the symptom, adjust the cause!
Old 01-20-2009, 02:12 AM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Nice to know. Thanks!
Old 01-20-2009, 05:44 AM   #7
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Now thats not even fair I just searched for it before I posted>.<
Thanks a mil for the link though^-^
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 05:23 PM
BIG(GER)TM BRAKE KIT Vanderkitten Performance Modifications 23 01-04-2009 07:16 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
