Old 02-13-2009, 09:13 AM   #1
ruimond
Drives: Yaris YR
Underdrive Pulley Belt
Im fairly new to knowing what certain parts of my car are. So just a quick question to those who have the NST Underdrive Pulley. I've had my Underdrive pulley for 2 months maybe, and whenever i start up my car...i think its my belt that sounds a little loose. It does not however sqweel or anything. The car drives fine and there is no worrying sounds to be heard when accelerating.
The question is im looking at getting a shorter belt sometime so i don't have to have it at almost the max tensioner setting. For those who have a shorter belt, what is the belt called? and what length did you buy?
Thanks in advance
Old 02-13-2009, 11:21 AM   #2
There shouldn't be any need for a shorter belt with that pulley. Have you re-tensioned it? I have a few thousand miles on mine with no problems, but I did re-tension it once.
Old 02-13-2009, 11:43 AM   #3
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
+1, i didnt have to get a new belt either. still had plenty of adjustment left.
Old 02-13-2009, 02:42 PM   #4
NonStopTuning
Copy and paste of our PMs...
Hi Mike,
Was wondering if you were able to answer a question for me.
I got my Underdrive Crank Pulley installed by my mechanic about a month or more ago now. But recently when i start up my car it sounds abit loose i think, well that or the engine has always been abit noisey anyway.
Just a general question, whats the belt called that drives the crank pulley? I need to get a shorter belt as mine is actually on the max tensioner setting. And was wondering if you knew what length was the best for the belt that drives that part. Im looking at buying a new shorter one.
Cheers
Hi Ruimond,
You should not need a shorter belt. The OEM belt works well with the Underdrive Pulley we offer.
However, belts are normal wear and tear items and they do wear out and stretch over time. You may be due for a belt change if yours has outlived the life expectancy.
Try a local auto parts store and buy the highest quality "crank pulley/ accessory belt" you can find for your car.
Good luck!
MIKE @ NST
www.NonStopTuning.com
Old 02-13-2009, 08:28 PM   #5
ruimond
Drives: Yaris YR
Thanks for the replies. I'll look at getting it re-tensioned first. The mechanic that put it on, im not sure if he re-tensioned it, i know he just adjusted the belt setting to almost the end because the underdrive is smaller so it had more slack in the belt.
Does re-tensioning require you to do something else?
Not sure if im due to change my belt as Mike said, i've only got about 33,000+km's on my car. But i'll get that looked into as well.
Old 02-13-2009, 08:58 PM   #6
there's a special tool, looks like a giant screwdriver that you use to adjust belt tension.
Old 02-13-2009, 10:10 PM   #7
ruimond
Drives: Yaris YR
Ok thanks cali :D I will see if i can get someone to tighten the belt with that.
Old 02-14-2009, 06:49 AM   #8
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
hmmm very strange I installed my underdrive pulley my self and only ad to adjust the alternator about an inch with plenty of room for further adjustment.... you can see pictures of it here:
http://www.yarisworld.com/forums/showthread.php?t=13270
Old 02-14-2009, 06:53 AM   #9
CtrlAltDefeat
I ♥ Yaris
whoops i forgot to take a pic of it after the adjustment err well if you want me to I can take a pic tomorrow to show the difference...
Old 02-14-2009, 07:06 AM   #10
ruimond
Drives: Yaris YR
Really? Mine was adjusted almost to the maximum. Maybe yours came with a shorter belt to begin with. Haha.
Old 02-14-2009, 07:35 AM   #11
CtrlAltDefeat
I ♥ Yaris
err possibly I guess... regional differences maybe...
Old 02-14-2009, 09:05 AM   #12
jonismyname
Drives: 08 liftback 5spd
factory belt is 25-040465 gates number.
040=4ribs, 465=47" length.
25040460 46 5/8
25040450 45 3/4
napa #'s, around $23 ea.
there's no reason you can't go shorter if you're unhappy with your current adjustment possibilites.
jonismyname is offline   Reply With Quote
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 05:41 AM
Brand new NST 10% Underdrive Crank Pulley trini_per4mance Items for Sale by private party 26 02-10-2009 05:35 PM
FOR SALE: NST 10% Underdrive Crank Pulley Yaris T-Sport Items for Sale by private party 9 01-16-2009 12:09 AM
Underdrive Pulley ruimond Performance Modifications 17 01-12-2009 07:11 PM
NST 10% underdrive pulley mrbond Items for Sale by private party 6 12-18-2008 06:35 PM
