Old 02-16-2009, 09:58 PM   #1
jonismyname
Drives: 08 liftback 5spd
megan lowering springs- brief review.
installed today. drop is rated at 1.5", appears actual. nice springs, standard in front, progressive in rear. (car is hatchback)
first impression was the springs felt smoother than stock. this was on a crappy back road with lots of pits, dives, heaves, sand, ice, and other terrible things, around 40ish mph.
once i got about 50 i quickly realized that these springs really are stiffer, and the car will jump around a bit more, a lot more feedback from the road, but not an obscene amount, still quite comfortable. but i do notice being pushed around in every which direction.
merging onto a highway, and throwing it into corners displayed a much flatter stance in corners, even without a rear sway bar. car changes lanes with attitude. very big difference.
drove about 3 miles with a fat guy in the back seat, and two big guys in the front. no rubbing. slowed the car down though. felt like i was driving my geo metro again.
i have no experience with any other lowering springs, but i can say, for the $$, the megan ones are great.
for anyone considering lowering springs, that live in an environment similar to mine (upstate NY, rural...) the noise from salt, sand, snow, and everything else covering our roads is about 3 times louder now that the car is sitting closer to the ground. a case of rubberized undercoat with dampen it a bit come spring, but it is something else to consider.
i looked for info on these springs before i purchased, and found none, so now, there's a write up. all be it brief.
jonismyname is offline   Reply With Quote
Old 02-16-2009, 10:05 PM   #2
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Nice writeup mate...
Old 02-17-2009, 01:48 PM   #3
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
I have them on my sedan as well. I think I did a write up on them pre-hack. The ride to me felt the same as stock. It only was rough over 80 mph, but thats the same as the stock springs. I noticed a slight increase in handling, but even after getting wider wheels I am still not satisfied with its handling. I can definitely tell this is where a sway bar comes in, hopefully my next mod.
Btw did you cut your bumpstops?
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 02-17-2009, 05:31 PM   #4
jonismyname
i left bump stops stock, called megan racing before i put them back together.
the car is def stiffer to me, i feel slight accelerations in every which direction while driving, the road pushing me and the car around in different directions. to describe it to people, i say, go-kart like.
a rear swaybar would def set the whole thing off, but i feel i need it much less now.
Old 04-30-2009, 08:28 PM   #5
Pitt Yaris
Drives: Flint Mica Sedan
Good review, how do these compare to nf, df, progress when it comes to drop? Do you have any pics? I wish there was just one or two brands of springs or a huge majority for one spring, instead of 4-5+ options. I've been going back and forth for months on which springs to get and still can't make up my mind. *Sedan, crappy winters, crappy roads*
Old 04-30-2009, 08:48 PM   #6
definitely post some pics! any idea what the spring rate is at least in front?
Old 05-01-2009, 03:36 AM   #7
eii
Rides canyon walls
eii's Avatar
I've never been in another yaris with aftermarket springs, the megan ones are the only ones I've had on my car. People have tried to figure out what the spring rates on these springs are, but no one has been able to find out what they are. Might have to do with why they're so cheap. They make my car look hella good though
Old 05-01-2009, 04:35 AM   #8
Pitt Yaris
Pics and what about ride quality and rubbing?
Old 05-02-2009, 05:20 AM   #9
eii
Rides canyon walls
eii's Avatar
Heres before, after, and after with 17"s pix:
Ride quality was not too stiff, almost felt like stock springs. I have no rubbing with my stock steelies, and no rubbing even at full turned u-turns on 17"s with 205/40 falken ziex-912s.
Old 05-02-2009, 05:34 AM   #10
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
rough over 80mph? After my Tanabe DF210s, before my rear sway bar, I had it up to 115mph (It was kinda an emergency) and it was rock solid... Every car I ever had felt floaty and any where near that speed (actually I'm not sure I ever had any thing that fast before). I had my 1.0L 3cyl geo metro up to 90-something and it felt like it was going to vibrate apart lol of course it was a geo metro
Old 05-02-2009, 10:25 AM   #11
eii
Rides canyon walls
eii's Avatar
actually i dont know why, but i havent noticed a difference over 80mph anymore. Dunno what happened.
Old 05-02-2009, 01:51 PM   #12
CtrlAltDefeat
I ♥ Yaris
maybe they settled since then...
Old 05-02-2009, 04:01 PM   #13
eii
Rides canyon walls
eii's Avatar
Yeah, it's what I was guessing. I also got 7" wide wheels now so that might have added some stability. Whatev's I dont care too much about the ride quality.
Old 05-02-2009, 09:55 PM   #14
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Do this. I installed a sway bar on my car and it made a world of difference.
Old 05-03-2009, 01:41 AM   #15
CtrlAltDefeat
I ♥ Yaris
me too
Old 05-03-2009, 04:16 AM   #16
Yeah, I had Megan springs on my GTI. Ride quality barely changed, but so did the ride height.
Old 05-03-2009, 09:46 PM   #17
Pitt Yaris
Yea, the drop looks like the nf210s, but I'm sure both are comfortable.
Old 07-15-2009, 12:43 PM   #18
hafeez
Drives: 2007 Silver Toyota Yaris Sedan
i got these springs on my sedan with tokico blues up front and stock shocks in the back. the front bounces a little bit while driving. i cut the bumpstops in half because I had the DF210 springs before and it was too much of a drop for me so i used back the same bumpstops. anyone know what could be causing this bounce?
hafeez is offline   Reply With Quote
what to look out for when installing lowering springs songa Performance Modifications 34 09-15-2012 03:29 AM
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
Megan Racing Lowering Springs TheRealEnth Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 11-14-2008 09:29 AM
Megan Springs: A quick review WRBlue Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 07-17-2007 04:00 PM
Will putting new lowering springs damage original shock absorbers in the long run? Joel Leong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 06-07-2006 08:30 AM
