Old 02-21-2009, 02:23 AM   #1
DIY - rear sway bar [pics]
Today we installed an Ultra Racing rear sway (anti-roll) bar on Babie Y's Yaris. I took a few pics, hope this is helpful.
First, jack up the back of the car (from the sides) and remove the rear wheels. This makes it easier to get to the bolts later.
Then, get out your sway bar. A friend, helper, bodyguard or whatever helps.
Look under the car. There is one large bolt holding the bottom of the rear shock. You can re-use this bolt. There is also a hole that isn't being used just in front of it, like this:
Here is the same two holes, shown from the inside angle instead:
Remove the bolt holding the shock. Place the swaybar with the bar at the bottom and so the holes line up. Re-install the bolt through the shock, then the sway bar, then a washer and nut. ***It is easier to do both shock bolts first, leaving the sway bar hanging -- then do the two front bolts.
That should look like this:
And like this:
Tighten and/or torque the nuts and you're done. In another thread there was consensus that "making them tight, but not crazy tight" was good enough for this.
thanks to supmet:
For the TRD bar, the torque specs are 36 ft/lbs on the bolt at the bottom of the suspension, and 44 ft/lbs for the other bolt.
Go drive the car, high-five your bodyguard... and have a nice day.
* (check and re-tighten, if needed after driving for a few days).
* the Ultra Racing sway bar comes with hardware -- I'm sure the TRD one does, too.
* Yes, that is a Tokico shock.
Old 02-21-2009, 03:41 AM   #2
Sweet. Thanks for the write up, Garm. I might be working (no, not the work I'm doing now, but actually be getting paid for working) this summer in addition to my summer classes. This will be one of the things I'll be getting if I get the position at the hospital.
Old 02-21-2009, 04:13 AM   #3
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Question though, does it really make a compareable difference over stock, and i don't know if you sell both of them would you recommend the Ultra or the TRD one? They are both at a competitive price..
The yaris is lowered on 17's, and she likes to take corners hard...
I'm going to do some research on it, just wanted to hear it out of the mans mouth first hand
Old 02-21-2009, 05:52 AM   #4
1NZYaris1
1NZYaris1's Avatar
It looks just like the TRD one except it's WHITE
so if you want RED you have to pay more
dam i should have waited a couple of months
and just paint it RED
Old 02-21-2009, 12:42 PM   #5
There is no stock sway bar included with the car!
Yes, this bar makes a big difference in cornering. Out of all the "bracing" and "bars" this is the one to get first and the one you will feel.
I think TRD is overpriced, but as a customer, it is good to have choices in the marketplace.
Old 02-21-2009, 12:47 PM   #6
argh i gotta get one of these someday nice writeup!
Old 02-21-2009, 01:14 PM   #7
supmet
Drives: 2007 4 Door Yaris
Tighten and/or torque the nuts and you're done. In another thread there was consensus that "making them tight, but not crazy tight" was good enough for this, but if someone wants to post the torque spec for these bolts, that would be great.
Old 02-21-2009, 01:23 PM   #8
custom Lftback
custom Lftback's Avatar
what is the price for the ultra racing sway bar?
Old 02-21-2009, 01:31 PM   #9
custom Lftback
nevermind, found an older thread. $129 shipped.
Old 02-21-2009, 01:37 PM   #10
thanks for the torque specs, added to first post
Old 02-21-2009, 01:41 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
@cali: can you source unpainted (maybe just primered) bars?
Also, how thick is this bar compared with TRD?
Old 02-21-2009, 01:47 PM   #12
Ultra Racing 19mm, TRD 22mm (I'm told) -- I've tried both, can't really feel much of a difference.
Thinking about having them make a 23mm bar to play with.
Why would you want an unpainted bar? You can always re-paint it anyway?
Old 03-07-2009, 11:34 AM   #13
westgl
2008 Prht Miata Red
Drives: 2009 3D 4AM PWR Pkg, Yel Jolt
Ultra Racing Rear Sway Bar
I bought my UR Rear Sway Bar from Cali Yaris, it shipped fast, received it very quick. It is easiest to put it on the way Cali Yaris describes. A small Pry bar will help to spread the bar and get it into place.
Driving: I noticed that the suspension felt Firmer and not bouncy as it was before, it remove the wander that this car has. Iam not constantly stearing to stay straight. The Wander is mostly gone. The car feel's more solid.
Handling: The handling is much improved, I feel that acident avoidance is greatly improved.
The car still has a slight amount of wander, maybe it's in the front end??
My Car has the Electric upgraded package that includes the upgraded Goodyear tires, not the Bridestones. The GoodYear tires hold the road better, and are allot quieter with less road noise coming into the car through the tires.
G
westgl is offline   Reply With Quote
Old 03-08-2009, 10:54 AM   #14
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
meh.... when I installed the wife's TRD bar I just left the shock bolts facing the installed way and placed the new bolts facing the opposite way....
good write up GARM!
Old 03-10-2009, 07:09 PM   #15
auxmike
auxmike's Avatar
good write up GARM!
I did the same thing!
I think that's what it showed in the diagrams in the instruction sheet.
Old 03-10-2009, 10:15 PM   #16
Inspector14
Drives: 09 Yaris hatch, Meteor Metal
Installed my Ultra sway bar a couple of weeks ago. man the handling is improved. i can really toss that little car around. (not too much still a bit of ice, and i have my snow tires on)
install was a snap. though i didn't tighten the shock bolt on the left side down all the way (got distracted) and was getting a horrible thunk sound. easy fix.
Inspector14 is offline   Reply With Quote
Old 03-10-2009, 10:50 PM   #17
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Very nice , I still need to get one of these sway bars off you Garm .
Old 03-10-2009, 11:02 PM   #18
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Sorry for noob question.
Don't know much about rear sways bars, but how does this improve handling?
Being that it's a FF car (Front engine, Front wheel drive) and this is my first FF car.
Up until now, I've only driven FR or MR cars with front sway bars that make a huge difference.
Shed some light on grasshopper please.
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
DIY - TRD rear sway bar kurokoma-kun DIY / Maintenance / Service 0 10-20-2008 01:21 PM
