Old 02-28-2009, 02:07 PM   #1
06vitzRS
Drives: 06 Yaris HB
Sound deadening
I would like to add some sound deadening material to my yaris HB but i don't want to spend a lot of money or add a bunch of weight. From the research i've done, it's going to cost at least a few hundred to do a high grade job. I was thinking of using some insulation (it's basically bubble wrap with a silver lineing on either side.) as a base and then that purple insulation material that is found in small amounts already in the car, on top of that. Both materials are light and i can get lots of it for cheap.
So, i would like some feed back on whether my results will be minimal and not worth it or if you guys think my plan will yeild some half decent results.
My after market speakers are rattling my interior and i also want to reduce road noise.
4th year apprentice mechanic.
06vitzRS is offline   Reply With Quote
Old 02-28-2009, 02:30 PM   #2
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
hi i dont think you will be able to sound deaden the car without adding weight since the metrial is very dence and heavy i have done my lb with two layers of raamatt its well worths the money and weight . raamatt is not to costley compared to dynamat . not sure what product you may be wanting to use ? dont think the results will be worthwhile i would sound deaden any car i buy if given the chance . here is a picrure of mine done
[IMG][/IMG]
[IMG][/IMG]
pennyracer is offline   Reply With Quote
Old 02-28-2009, 05:29 PM   #3
06vitzRS
Drives: 06 Yaris HB
I guess i'll hold out for the time being and do it right. I think i may go with a paste, such as: http://www.secondskinaudio.com/sound...r/spectrum.php
Old 02-28-2009, 09:20 PM   #4
nemelek
DWEED
nemelek's Avatar
If you do it let me know how it works.
Old 02-28-2009, 10:38 PM   #5
YAR1S
YAR1S's Avatar
haha that guy on the website sounds so convincing.
-Jen <3
Old 03-01-2009, 12:39 PM   #6
mrrock
Drives: yaris 2dr hatch
I wouldn't do it your way; too much of chance for moisture to get trapped.
do it right or don't do it.
mrrock is offline   Reply With Quote
Old 01-18-2010, 10:00 PM   #7
pennyracer
boydstir
pennyracer's Avatar
i agree fully
Old 03-17-2010, 11:09 AM   #8
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Deadening is not cheap, but if you are going to spend $$$ do it with some knowledge, I'm doing my Yaris and it's a big learning process, it's fun and it's worth it. Here is some literature that helps a lot...
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
D.
CLA 250, 4MATIC
Old 03-17-2010, 12:25 PM   #9
swidd
Drives: Yaris HB
Looks like a 50 sq feet roll was enough to cover my trunk lid, doors and rear side panels in my hatchback. That alone helps alot.
Old 05-05-2010, 01:42 PM   #10
pennyracer
boydstir
pennyracer's Avatar
i used a bit more than that :)
Old 05-05-2010, 01:51 PM   #11
swidd
Drives: Yaris HB
I'm done now, and used 100 sq ft. Only place left naked was the inside of the front doors, the ceiling, and the top side of the firewall (didn't remove the dash). I spent $200. Worth it? Absolutely, but there is still a tiny little bit of noise left.
2009 - Radio/Aux jack sound issue bobfolgerjr New YARIS Purchase Forum 5 10-24-2011 04:21 PM
"Rotor" sound? texkid Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 02-22-2009 03:52 AM
Factory Sound System and iPod ARCVILE In Car Entertainment + Electronics (audio / video / alarm) 5 09-07-2007 11:40 AM
Chirping, squeeking sound ToTo Performance Modifications 7 04-21-2007 04:29 AM
Sound deaden-ers... anyone tired them yet? Speedz DIY / Maintenance / Service 2 01-27-2007 08:49 AM
