Old 03-05-2009, 01:43 PM   #1
cm07yaris
Drives: 2007 Toyota Yaris Blazing Blue
Send a message via AIM to cm07yaris
Fog Light Help
So I ended up getting the new headlight stalk with fog light control on it and something just isn't right. I have rechecked everything numerous times and for some reason the fog lights only turn on when the high beams are switched on. The fog lights are installed, with one wire to a ground, and the other into the proper pin in the fuse box under the hood. An OEM relay was also installed under the dash, and the new stalk was installed. Any suggestions why this would be happening?
cm07yaris is offline   Reply With Quote
Old 03-05-2009, 02:20 PM   #2
Did you already have the fogs wired, and then added the new stalk? This is what the wiring is supposed to look like when using the fog light switch on the stalk:
Old 03-05-2009, 02:26 PM   #3
Crandall
H8R
Crandall's Avatar
Drives: 08 White RS
I don't know if these would be the case, but my car came with a DRL module and when I disconnected it my fogs stopped working. If you've disconnected yours you might want to try reconnecting it and see if changes it.
Hope this was helpful.
Old 03-05-2009, 03:44 PM   #4
1NZYaris1
1NZYaris1's Avatar
have you disabled your daytime running lights.
that sounds like the problem to me .
Old 03-05-2009, 03:47 PM   #5
cm07yaris
DRL's have never been touched. I'm in the process of deciphering that wiring schematic. As far as wiring, there really wasn't much, just the ground and and the wire to the fuse box under hood...
Old 03-05-2009, 03:51 PM   #6
cm07yaris
I'm assuming that the high beam and low beam wires need to be switched in the plug that goes into the stalk?
Old 03-05-2009, 04:19 PM   #7
If you swap hu and hl then high and low functionality will be reversed. Did the new stalk replace the existing and the factory connector plugged back in?
Old 03-05-2009, 04:26 PM   #8
cm07yaris
Yup, ordered it from my local dealer, fit perfect, and the plug went right in. That's why I'm so confused...
Old 03-05-2009, 05:12 PM   #9
kenora
Drives: 2009 Yaris LE 5 dr
Can you tell me how much the new stalk was please?
kenora is offline   Reply With Quote
Old 03-05-2009, 05:26 PM   #10
cm07yaris
Dealer price is like $96.17 USD, fortunately I had gotten a coupon in the mail a day before it arrived.
Old 03-05-2009, 05:37 PM   #11
OK - So, new OEM plug and play stalk. Did you wire up the fogs, or were they already in and wired to a separate switch?
Old 03-05-2009, 05:39 PM   #12
cm07yaris
Installed the fogs myself. From the fogs there is a ground wire which I grounded by the driver side headlight, and another wire that I wired into the plug in the fuse box under the hood. Plugged the Toyota relay under the dash. Then installed the stalk and plugged in the harness.
Old 03-05-2009, 05:53 PM   #13
So, the only wires you actually had to connect were the ground and the fuse box connection. In that case double check the connection point in the fuse box to make sure that you're in the right position in the connector.
Old 03-05-2009, 06:04 PM   #14
cm07yaris
I have checked so many times!
Old 03-05-2009, 06:51 PM   #15
1NZYaris1
1NZYaris1's Avatar
okay the problem is your fogs are working in reverse to factory ,
the most likely problem is the relay is switching in reverse.
Talk to Garm at Microimage i sent him some relays and
wire set up for fog lights a week ago .
Old 03-05-2009, 06:58 PM   #16
Where did you tie to in the fuse panel?
What is the part number on the relay (1NZ might be on to something with the relay being a NO vs NC or vise versa)?
You plugged the Toyota relay into the open spot in the iside fuse panel right (It's not an aftermarket fog set that includes an inline relay correct)?
Old 03-05-2009, 09:54 PM   #17
cm07yaris
I've tried 2 different relays now, one is a Tyco and one is Toyota. I'm still hoping it has something to do with the relay. It really can't be anything else, unless the stalk is bad (doubt it). I'll post pics and p/ns of the relays tomorrow. Thanks guys.
Old 03-08-2009, 06:58 PM   #18
clh333
Drives: 2007 Yaris 2 Door
Fog lights
Could I ask: which Yaris are you driving? I bought my 07 hatch from a dealer who has flatly refused to help me outfit it with fog lights.
If there is an OEM light stalk with a switch for fog lights that fits my column, I'd like to know what part number to order.
Thanks!
clh333 is offline   Reply With Quote
Rear fog light for US '08 3Door Yaris (stick shift9 Stefan DIY / Maintenance / Service 21 04-21-2010 04:30 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
