Old 03-21-2009, 01:55 AM   #1
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
DIY Oil Pressure Gauge Install
This DIY is to show how I installed an Autometer C2 Oil Pressure Gauge. I did not take pictures along the way because the install took several weeks. I have gather a bunch of post-installation pictures and diagrams that should lead you towards your own installation.
A typical electric oil pressure gauge system is quite simple. It consists of a sensor, a cable, and the gauge itself.
The sender unit can be installed two ways. You can remove the factory oil pressure sensor and screw the new sensor into the factory tap. Doing so means that your OIL idiot light will no long work. Also, from the name of the device, the factory oil pressure switch seems to have only two settings...OFF or ON.
My supercharger intake manifold blocks my access to the factory oil pressure switch, so I decided to use a sandwich plate between the engine block and the oil filter. I got mine from Glowshift (thanks to Camelll for showing me this particular one).
In order to install the sandwich plate, the oil filter has to come off. Since my car is lowered, I stole someone's idea on this forum and built a homemade ramp to give me some room to work. It actually raised the car enough for me to get my body underneath the car if I wanted to. Who ever posted this idea, kudos to you!
Old 03-21-2009, 01:56 AM   #2
LtNoogie
LtNoogie's Avatar
Next comes the removal of the oil filter. There are several threads on what it takes to remove the oil filter so I won't go into it here. I just wanted to say I had to buy one of those endcap filter wrenches that you can put a 3/8 ratchet head into. Be sure to have a quart of fresh oil on hand because about a half quart of oil spills out when you remove the filter. I left what oil was in the filter and did not dump it out since I just got my oil changed 200 miles ago.
Things are tight down there so the new sensor needs to be screwed onto the sandwich plate before you attach the sandwich plate to the engine block.
The plate is screwed into the engine block and the filter is screwed into the sandwich plate. This picture is looking up at the filter and sender unit from the ground level. The sandwich plate is not visible when the filter is in place.
Here's a top view from the engine compartment.
Old 03-21-2009, 01:56 AM   #3
LtNoogie
LtNoogie's Avatar
The hardest part for me was bringing the wiring into the cabin of the car. I finally went to the local auto stereo shop and had an intaller drill a hole through the firewall and run the oil pressure wires and the vacuum/boost wires through the grommet. He also ran two 4 gauge wires for my future amp and subwoofer.
A gauge like this typically requires ignition switched +12VDC, dash lighting switched +12VDC, and ground.
I found the easiest way to tap into the +12VDC circuits was to use add-a-fuse circuits directly to the fusebox underneath the dash near the lever that opens the hood. You can get the add-a-fuse circuits at the auto parts store.
I tapped into the PANEL 1 circuit and the MET circuit. I don't remember which one went to which gauge wire. I'll have to check tomorrow. The smallest fuse I could find was a 3A fuse to use in the add-a-fuse circuit.
This view is looking directly up from the floormat.
Old 03-21-2009, 01:56 AM   #4
LtNoogie
LtNoogie's Avatar
Chassis ground can be found behind the kickplate near the driver's left foot for LHD vehicles. The plastic kick panel pops off easily. You will have to remove the doorsill plastic panel before removing the kick panel.
With power and ground connected, I connected the wire harness to the gauge to see if it powered up and lit up when I turned on the ignition and the headlights. The wire harness had not been connected to the oil pressure sender so the needle did not fluctuate. The wire harness was then wrapped in plastic slit tubing to protect it.
The little storage compartment near the driver's knee was removed to see if there was a way up to the dash. When the A-pillar cover was popped off, it reveal a path from the fusebox to the top of the dash.
This view is looking down through where the A-pillar was.
Old 03-21-2009, 01:57 AM   #5
LtNoogie
LtNoogie's Avatar
I'm currently using this Glowshift triple swivel gauge pod until I finish working on my A-pillar gauge pod. I should be finished with that task in 6 months at the pace I work.
I had to Dremel some holes in the back of the gauge pods because the pre-made holes were too small and were in an awkward position. The connectors were fed through the back of the gauge pod and pushed into the back of the gauges. The gauges were then pressed into the gauge pods.
I also ran my ScanGauge cable up the same path.
Old 03-21-2009, 01:57 AM   #6
LtNoogie
LtNoogie's Avatar
Vacuum/Boost is on the left. Wideband AFR is in the middle, Oil Pressure is on the right. In the video you see a black foam sheet on top of the gauges to block their reflection off the windshield. I need to make a little shroud over the gauge pods. At night the blue illumination also reflects off the windshield and is really annoying.
http://www.youtube.com/watch?v=3XsfSoKuDxU
Old 03-21-2009, 03:01 AM   #7
1NZYaris1
1NZYaris1's Avatar
you are right with the factory Oil Pressure sensor it is pure on/off
for the warnning light on the dash , that's why the scangauge can't read it . just a bit of useless info for everyone.
Old 04-03-2009, 01:30 AM   #8
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
hey awesome DIY, can you tell me what exact oil filter sandwich adapter you used? there are many different thread sizes to choose from, im not sure what ours is. i have my glowshift guages installed, now im just trying to set-up the oil pressure signal etc. thanks
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 04-03-2009, 01:49 AM   #9
LtNoogie
LtNoogie's Avatar
This is the one that Camelll and I used. Good luck with your install.
http://www.glowshiftdirect.com/oilfi...-34unf-16.aspx
Old 04-03-2009, 02:20 AM   #10
Kenshin
Kenshin's Avatar
Drives: 2008 Blazing blue Met. HB
Has anyone done this with aftermarket synthetic filters? Mine concaves down and I had to buy a new adapter, but still when the car starts, oil drips out of the filter-sandwich adapter. . .so I disregarded this mod. I'd love to do it one day, but I'd have to pick up an OEM toyota filter again. . .Anyone else experienced problems with this sensor gauge mod?
Kenshin is offline   Reply With Quote
Old 04-03-2009, 12:49 PM   #11
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
Nice DIY, Long. Thanks!
Mike... what's "pipe dope"?
2006 Red Blitzed RS 5-door
Old 11-13-2009, 09:14 PM   #12
yoxx
yoxx's Avatar
Drives: toyota yaris 2008 hatch
Exclamation
wich one spesificaly did you buy??
i whent to the shift glow page but they have many diferent size of adapter, what size does it fit the yaris??
thanks
yoxx is offline   Reply With Quote
Old 11-13-2009, 09:21 PM   #13
yoxx
yoxx's Avatar
never mind i got it
Old 11-20-2009, 04:13 PM   #14
yoxx
yoxx's Avatar
Thanks men that adapter work perfect, just my oil pressure on with the adapter work great
thanks again
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
$30 Oil Catch Can, DIY Ogredude DIY / Maintenance / Service 79 05-13-2011 11:05 AM
Are these oil pressure readings within range? LtNoogie Performance Modifications 14 03-21-2009 12:35 AM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 11:36 AM
