07-12-2009, 08:13 PM | #1 |
╚══════════RN
Dual antennas
So I think this is going to be temporary. The mounts are not as strong as I would like them to be. This is turning into such a pain.
Passenger side is an AM/FM 3' Firestik, and the driver side is a Wilson FGT 3' CB antenna.
42.88 |
07-12-2009, 08:47 PM | #2 |
looks like Atom Ant , with bloody big feelers .
looks cool though |
07-12-2009, 11:45 PM | #3 |
Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Diamond makes some nice mounts, though they are pricey.
They come in black as well. http://www.rfparts.com/diamond/k400photos.html Here is the main page for mounts. http://www.rfparts.com/diamond/Produ...og/mounts.html The K600 series looks interesting. Just a thought. How did you end up mounting the radios inside the car? Last edited by Revsson; 07-12-2009 at 11:55 PM. Reason: added another link |
07-13-2009, 12:12 AM | #4 |
Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
I had a wilson 1000 magnetic once. Those look kinda odd and a temptation for vandals or curious kids. Also, it screams "hey, I've got real expensive radio gear in my car".
Never take eyes off opponent - Bruce Lee |
07-13-2009, 11:27 AM | #5 |
╚══════════RN
This is how I mounted my CB radio and stereo:
http://www.yarisworld.com/forums/showthread.php?t=17834 I think I'm going to end up buying one of those lip mounts. It's pretty much my only option. I did have some mirror mounts that I had screwed to the car, underneath the plastic triangle piece in front of the sideview mirrors. I figured it was just one sheet of metal I would go through, but there are about three layers, some are weak and give way as I was screwing in my self tapping metal screw -- it just wasn't good. I think I could easily get away with a lip mount on the fender... or get a 102" whip and a beefy Wilson roof mount. If you notice in my pictures, I removed the factory antenna completely. Had to drop the headliner and all that jazz.
42.88 |
07-13-2009, 11:49 AM | #6 |
╚══════════RN
$76 dollars fors a K400?!?!
There has to be a cheaper option...
42.88 |
07-13-2009, 12:50 PM | #7 |
07-13-2009, 12:55 PM | #8 |
╚══════════RN
I'm a ham, and I could see paying for that mount if I had some big whopper expensive HF antenna... but for a 3' CB radio antenna, grrr. I gotta try and find something cheaper -- or attempt building something else.
42.88 |
07-13-2009, 05:43 PM | #9 |
╚══════════RN
Bought a 102" whip this afternoon, pulled off the rear bumper, and test fit it on the actual metal bumper itself. It was a no go. Too much in the way, though it did just barely clear the hatch on opening and closing.
Looks like I'm back to the drawing board...
42.88 |
07-14-2009, 01:17 AM | #10 |
Maybe you could make something like this?
I'm trying to picture how that would look on a Yaris. http://www.mfjenterprises.com/Produc...uctid=MFJ-2820 |
07-14-2009, 12:08 PM | #11 |
╚══════════RN
The hatch would definitely whack the antenna. =/
*inaudible noises of frustration* That's a cool idea though.
42.88 |
07-14-2009, 12:15 PM | #12 |
╚══════════RN
Maybe there's a way to mount it on the sideview mirror... I may take one apart later on. But then again, I'm not sure if the plastic would be strong enough to support it -- or that I could even get a good ground.
42.88 |
07-16-2009, 12:47 AM | #13 |
07-16-2009, 11:50 AM | #14 |
╚══════════RN
One thing similar to that that I was thinking about... Having someone weld a tab onto my tow hook and mounting a 102" whip off that.
42.88 |
07-16-2009, 01:14 PM | #15 |
Drives: 2008 Yaris LB Join Date: Dec 2008
you could probably modify that license holder bracket to be attached to your mudflap (or mudflap area if you don't have them). Good placement and a good sturdy mount point.
07-17-2009, 02:48 PM | #16 |
Drives: yaris sedan Join Date: Oct 2008
07-17-2009, 03:47 PM | #17 |
Drives: 07 Yaris Turbo Join Date: May 2007
looking at post #1, couldn't you bend them back and attach the tips to the roof just above the doors?
Or is there some technical reason (reception and suchd) why that's a bad idea?
07-17-2009, 10:02 PM | #18 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
The ideal way to go would be to punch two holes in the roof. My father's been a HAM for 40+ years. The first thing he does when he buys a new vehicle is to punch a hole in the roof (drills a pilot, then uses a metal punch) and uses an NMO type mount.
Similar Threads | ||||
Shark Fin and Short Antennas | JustAnotherAsian | Cosmetic Modifications (Exterior/Interior) | 137 | 04-21-2009 04:46 AM |
dual antennas? | Yanick | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 11-10-2008 12:18 AM |
dual exhast | msfire671 | DIY / Maintenance / Service | 9 | 10-24-2008 08:24 PM |
dual batteries or use a cap? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 07-17-2007 03:19 AM |
Dual Exhaust | elsteverino889 | Performance Modifications | 74 | 05-02-2007 09:08 PM |
