Old 07-13-2009, 04:15 PM   #1
shangapol
Drives: Yaris Sedan
Exclamation HELP!!, HOW TO INSTALL FOGLIGHT YARIS SEDAN??
PLEASE, I bought the DLAA FOGLIGHT and I do not know how to install ... PLEI bought the DLAA FOGLIGHT and I do not know how to install ... PLEASE only need the connection diagram. I HAVE A CABLE CONNECTOR WITH A RED AND WHITE CABLE TO ANOTHER, I DO NOT CONNECT THESE...
PLEASE HELP ME!!!
shangapol is offline   Reply With Quote
Old 07-13-2009, 04:51 PM   #2
Lafiro
Drives: 06 Yaris Sedan
Ok first no yelling. We respect eachother here. Next we need pictures ofthe cables and the fog lights and from there we can help explain how to install them. Also there are two other threads just in the last few days here just on this exact topic so please read those as well and I or someone will help you.
Old 07-13-2009, 04:53 PM   #3
shangapol
Drives: Yaris Sedan
this is the light
HELP ME!!!
Old 07-13-2009, 04:54 PM   #4
shangapol
Drives: Yaris Sedan
sorry bro!!!
Old 07-13-2009, 05:17 PM   #5
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
Originally Posted by shangapol View Post
sorry bro!!!
Then edit your request. Put the request in normal lettering like every one else.
ellenbetty is offline   Reply With Quote
Old 07-13-2009, 05:32 PM   #6
1NZYaris1
1NZYaris1's Avatar
Are you trying to plug it into the factory wireing .
if so you will need to follow the PDF and redo your wiring on the kit .
Opp's the file is too large to post up here , PM me your email and i will send it to you .
Old 07-13-2009, 08:31 PM   #7
shangapol
Drives: Yaris Sedan
done!! sorry
Old 07-13-2009, 08:41 PM   #8
1NZYaris1
1NZYaris1's Avatar
Emailed you
Old 07-13-2009, 08:45 PM   #9
shangapol
Drives: Yaris Sedan
Emailed you
send me again the email....i can't find them
Old 07-13-2009, 09:06 PM   #10
1NZYaris1
1NZYaris1's Avatar
Try now
there is two + 1 i just sent
Old 10-22-2012, 04:39 AM   #11
seechoong
Hi 1NZYaris 1, can you email me the PDF of fog lamp installation? Lauprada@gmail.com. Thanks bro
seechoong is offline   Reply With Quote
Old 11-27-2012, 05:57 PM   #12
kropekoi
Drives: vios 1.3J
hi 1NZYaris, can you also email me the PDF? v-2majim@hotmail.com, thanks!
kropekoi is offline   Reply With Quote
Old 11-28-2012, 12:53 PM   #13
Tomatogrower
The Flying Tomato
Tomatogrower's Avatar
Drives: 2009 Red Yaris Hatchback
Lol, I think I have the same (if not similar) kit. Please see my inquiry post about my wiring questions and related issues I encountered:
http://www.yarisworld.com/forums/showthread.php?t=41479
Be extremely cautious when getting the kit wired and running the lights. As CTScott has said many times, these kits are common to have faulty relays. The relay that came with my kit failed and blew my tail fuse (luckily that was the only damage incurred...definitely could have been much worse). As CTScott recommended in my post, it would probably be best to rewire the kit with the OEM wiring method with the OEM relay. Either that or get the kit from MicroImage.
Tomatogrower is offline   Reply With Quote
fog, light, sedan, yaris
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
Yaris Sedan Vs. Yaris 4dr. hatch Meow General Yaris / Vitz Discussion 11 10-29-2006 02:11 PM
