Old 08-26-2009, 10:43 AM   #1
DOMAV
Drives: Yaris 09 T-spirit 1.33
cup holder removal
hi can someone help me and tell me how to remove the cup holder the one at the top near the steering wheel ?
DOMAV is offline   Reply With Quote
Old 08-26-2009, 10:47 AM   #2
SweetRS
Drives: 2006 Yaris Rs
i second this....damn spilt coffee stains!!
SweetRS is offline   Reply With Quote
Old 08-26-2009, 11:04 AM   #3
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
It's actually pretty tricky. You have to open it first, then squeeze the sides in. There is a little plastic piece that prevents it from falling out, and you have to kind of stick a flat head screwdriver in there to make it come out.
Oh and make sure you remove the screw from the bottom of the holder (visible only when the cup holder is open).
I'll see if I can post pics up a little later on today. I took mine out and put them in the dishwasher.
devinlamothe is offline   Reply With Quote
Old 08-26-2009, 11:40 AM   #4
DOMAV
it would be great if you have some pics thanks
Old 08-27-2009, 01:53 AM   #5
Revsson
Sorry, couldn't resist putting that in.
Old 08-27-2009, 02:00 AM   #6
IsLNdbOi
IsLNdbOi's Avatar
Instead of removing it, why not just stop using it? What are you going to do with that space where it once was?
Old 08-27-2009, 02:26 AM   #7
DOMAV
no i'm not going to remove it i want to change it cause its all marked in the front, actually my toyota is new and the toyota dealer is going to change it for me for free,
i want to know what it needs to be done so when i go and collect my car i see if the damaged the surrounding from where they took it off
Old 08-27-2009, 08:06 AM   #8
devinlamothe
Sorry for no pics yesterday, I totally forgot. Will go out and grab some pics in a few.
Old 08-27-2009, 08:39 AM   #9
devinlamothe
Ok so here goes. Don't mind the coffee stains lol cups tend to spill a lot in these holders, they get all the vibration from the road.
1) Remove the screw. I don't know if this is absolutely necessary but I do it anyways.
2) Take a thin screwdriver and try and pry one side, while taking your other hand and squeezing both sides together. You have to pull quite hard to get the top portion to come out. So don't be shy here.
3) Once the top piece is out, take your small screwdriver and pry & pull the clips near the bottom. There is one clip on each side, but the clip on the left is the easiest to get off first.
Old 08-27-2009, 11:32 AM   #10
DOMAV
thanks for all your help
CUP HOLDER REMOVAL? SweetRS Cosmetic Modifications (Exterior/Interior) 13 09-19-2016 08:43 AM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-19-2009 11:40 PM
reusable water bottle in the bottle holder 50MPGDream General Yaris / Vitz Discussion 24 01-28-2009 01:51 PM
A eye for a eye but a Ipod for a cup holder? yrsdrgn DIY / Maintenance / Service 30 05-08-2007 02:51 AM
