09-30-2009, 12:08 AM | #1 |
Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
Blinding blue indicator light
When driving the Yaris on dark nights the blue high beam indicator light is so bright that it becomes annoying. I thought I read some where that a resister can be added to reduce the intensity of the light. Has anyone had any success with a fix for this one?
Thanks, Birdman |
09-30-2009, 12:22 AM | #2 |
Just call me Ray, better?
i always half-ass the high beams so it doesnt come on, pretty much inbetween hi and lo it shines more aswell
09-30-2009, 12:26 AM | #3 |
i know, but it blinds when it is really dark out and it gets destracting
09-30-2009, 12:33 AM | #4 |
lol, ok maybe not blinds but still annoying,
09-30-2009, 12:35 AM | #5 |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I also find it VERY annoying. I'm about ready to put electrical tape over it
09-30-2009, 12:37 AM | #6 |
or just do what i do
09-30-2009, 01:31 AM | #7 |
You're right,"blinding" is an exaggeration. When I do long late night commutes and my eyes are tiring the brightness of the blue light is annoying, For now I wad up a paper towel to cover it.
09-30-2009, 02:25 AM | #8 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
Some well-placed scotch tape to diffuse the light a bit?
09-30-2009, 02:27 AM | #9 |
The tape is an option but I'm hoping for an electrical fix. Thanks for the idea.
09-30-2009, 04:11 AM | #10 |
Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Upgrade your headlights to bi-xenon HIDs from Xenon-Vision. For some reason, the way the kits gets wired, it stops the hi-beam indicator from lighting up on the cluster even though the hi-beams work perfectly.
09-30-2009, 04:21 AM | #11 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
Just don't drive with hi-beams on in the first place. If that little blue light annoys you, just imagine how the driver in front of you feels
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
09-30-2009, 06:24 AM | #12 | |
Beast
One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
09-30-2009, 10:06 AM | #13 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
In the picture below, you can see the BEAM LED (D559). You could change its current limit resistor (looks like R640 {which is currently a 202 ohm resistor}, following the trace) to a higher value. Or, a much easier approach is mechanically reduce its output. My standard method for toning down overly bright LEDs on things is to simply dab the LED's lens with a black Sharpie marker. You can also use a think piece of gray or semi opaque plastic.
Beam LED.jpg |
09-30-2009, 10:11 AM | #14 |
Drives: 2007 Yaris Hatchback Join Date: Jul 2007
i really dislike blue LED indicator lights that show up on everything these days, it truly is annoying, and the blue itself is way too bright; as for the dashboard, i think it makes sense to have one as you don't want to be driving around with your brights on all night-- that's not fair to others, so you should be reminded that it is on; even if it's a tad annoying. so to sum up, I bring nothing productive to the OP, hah :D
you could always crack open the dash and just replace the LED, or add a piece of painters tape onto the front for long drives |
09-30-2009, 10:45 AM | #15 | |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
09-30-2009, 01:45 PM | #16 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
Yeah if you can get at the circuit board masking the LED itself is the way to go.
09-30-2009, 02:06 PM | #17 |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
There have been studies that show blue light creates more eye strain than any other color, but as others have pointed out, its a function, not a side effect.
09-30-2009, 03:22 PM | #18 |
Modded Moderator
My '71 ford had a red light for the high beam. Much nicer.
Similar Threads | ||||
F/S Blue Stitched Leather Shift Boot. | 1NZYaris1 | Items for Sale by private party | 9 | 05-06-2009 11:59 PM |
Bayou Blue paint code | andru47 | General Yaris / Vitz Discussion | 7 | 01-03-2009 04:19 PM |
Blue Film over gauges | Jeff1 | DIY / Maintenance / Service | 10 | 10-21-2008 03:01 PM |
Black or Blue | CrashRescueFF | New YARIS Purchase Forum | 18 | 07-24-2007 07:21 PM |
Nautical Blue Metallic | YotaYarisUSA | General Yaris / Vitz Discussion | 0 | 04-02-2006 07:09 PM |
