Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 11-03-2009, 10:18 AM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
How to Disable Trac Control/VSC on the Yaris TS
Info below provided by ANDRIES and I have personally confirmed that it works on 07/08 models.
switch off TRC and VSC
Oke, here we go;
baseline, engine is off en handbrake is off (downwards)
0. put the key in "contact"
1. clutch downwards
2. handbrake on (up)
3. start engine
4. push twice on the feet brake and by the second time keep it down.
5. handbrake off (down), handbrake on (up),handbrake off (down), handbrake on (up)
6. again push twice on the feet brake and by the second time NOT keep it down.
TRC and VSC lights go on. Both systems now off.
To put the systems ON simple switch off the engine. When you start again the systems are working normal.
I hope I have made a translation in English you understand.
Let me know if it was successful to switch it off.
Good luck
Andries
Old 11-03-2009, 11:13 AM   #2
andries
aka Jack Wolfskin
Send a message via MSN to andries
andries is offline   Reply With Quote
Old 11-03-2009, 02:36 PM   #3
tcpty
TSport Underdog
tcpty's Avatar
Drives: 2008 TS Storm Gray
Castrex, I read you have Smart Entry & Start System on your car, just like mine
How do you do the first step - key in "contact"? Just clutch in and Start the engine?
Also, can you tell me where can I find these hidden electronic "secret" programming tidbits? I want my car to auto lock the doors when you start driving (30 kph or so) and unlock when you shut the engine off (I had a 2008 Hilux that had this info on the owners manual and I was successful in programing it - since the local dealer here does not help us much in getting info like you posted)
tcpty is offline   Reply With Quote
Old 11-03-2009, 03:02 PM   #4
CASTREX
CASTREX's Avatar
On the smart entry system the "key in contact" is just one click on the ignition. So the light on the start turns in orange. No need to push the clutch. is just the equivalent to start the ignition.
It was Andries who found this little trick!! I have no idea where e got it.
This is actually intended to put the car in "Dealer Mode" for revisions and such.
Old 11-03-2009, 04:02 PM   #5
tcpty
TSport Underdog
tcpty's Avatar
I actually went and got it right the first time!
It's kinda funny to do all the steps to get there.... but you DO get there! I took it for a drive around the block (it's raining cats and dogs right now here in PTY) and with the NST pulley and TC off you definitely feel more spirited response (and wheel spin in the wet)
Thanks again
TC
Old 11-04-2009, 09:37 AM   #6
127.0.0.1
This works on 2010 Yaris automatic
disable TRAC and VSC
within 30 seconds
start car
footbrake off
handbrake ON
2 foot-brakes
handbrake off
foot-brake ON
2 handbrakes
foot-brake off
handbrake ON
2 foot-brakes
Trac light will illuminate indicating vsc and trac disabled.
will reset next time car is started
Old 11-28-2009, 10:16 AM   #7
StreetVibeTS
StreetVibeTS
Drives: yaris 1.8 ts
hehe it worked perfectly on myne...the car is much different to drive with the VSC turned of, feels more powerful too
StreetVibeTS is offline   Reply With Quote
Old 01-16-2010, 02:58 PM   #8
Bogey
Drives: Toyota Yaris T-sport P1
maybe somebody knows how to turn off VSC and TRC in toyota yaris t-sport 2005 manual, there is switch for TRC, but 'system' of turning off vsc not working, maybe i'm doing something wrong, but following given instructions any ideas?
Bogey is offline   Reply With Quote
Old 01-18-2010, 01:42 PM   #9
127.0.0.1
if you have a switch
you hit the switch to disable trac, it will re-enable trac when your
speed increases
you hit and hold the switch, it will disable both trac and vsc, and that will not re-enable when speed increases
that is how it is supposed to work when you have 'the button'
Old 02-07-2010, 02:24 PM   #10
Valentino
Valentino's Avatar
Drives: Yaris TS 1.5 [NCP13]
Hi,
very first post from Italy...
I've tried it on my Yaris TS MY03 1.5 just for disable the VSC, for the TRC I've got a specific button but, seems doesn't works....
Anybody knows if there's any other "cheat" that works on my car?
Thanks
Valentino is offline   Reply With Quote
Old 02-14-2010, 10:22 AM   #11
Stiv
Drives: Yaris TS 1,8L
Well guys, I turned of VSC using this method as I did a few times before. Eight of us went to a snow and ice covered empty parking lot and had realy good time :)
In the middle of that 50 minute driving check engine light came on. From that moment on, VSC and check engine became permenanty lit.
Today I decided to desconnect battery to reset error code. Now everything works fine.
My guess is that this way od disableing VSC is for diagnostic purposes only. The car thought there is an error vith VSC and disabled it permanently. What do you think?
Stiv is offline   Reply With Quote
Old 02-14-2010, 04:45 PM   #12
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
hmmm, what driving aids usually come with the Yaris? I know ABS was optional....but VSC?
Old 02-15-2010, 12:34 PM   #13
Jacksonville
Drives: 2010 Hatch
works on 2010's!
Jacksonville is offline   Reply With Quote
Old 03-12-2010, 06:59 AM   #14
candy_red
Drives: 2000 Yaris 1.0 & 2007 Yaris Ts
The vsc code works fine,
did you find out how to do the code with the automatic door lock?
candy_red is offline   Reply With Quote
Old 03-12-2010, 10:21 AM   #15
tcpty
TSport Underdog
tcpty's Avatar
Nop
Old 06-18-2011, 11:07 PM   #16
fase4
Drives: Yaris TS 05
Bogey i have the same problem of you... we need some help here
fase4 is offline   Reply With Quote
Old 08-04-2011, 08:10 AM   #17
carlo0616
Get a piece of wire and short pins 4 and 12 on the obd port briefly just after you start the engine.
This should make alot of lights flash on the dash. Now turn off the engine again without the shorting wire and you should have tc and vsc lights on the dash.
To turn it back on
Short those two pins before the engine is started and leave it In while you start the car
Now pump the brake pedal around 10 times
Turn the engine off, remove wire
Now it will be reset
carlo0616 is offline   Reply With Quote
Old 08-29-2011, 06:35 PM   #18
fase4
Drives: Yaris TS 05
thank! just you should make a video demonstrating how to do it since my English is not very good
