03-23-2010, 08:40 PM | #1 |
Just a Herbicidal maniac.
Drives: 2008 Yaris S Sedan Flint Mica Join Date: Oct 2008
Tanabe front strut tower brace.
I bought one from Garm at Micro Image and recall seeing this install tip on his web page:
Adjustable Preload: A very common error when installing tower bars, it is always recommended to raise the vehicle when installing so that the load of the shock uppermounts on the shock towers is relieved and balanced out. When raised, and the tower bar is placed onto the vehicle, the preload can be adjusted and set. After it is bolted on and the car is lowered, each shock tower will have equal load and will prevent independent movements of each shock. This will provide an extremely noticeable difference after installing. If a tower bar is installed on a car that is not raised, great benefits will be missed. I read through earlier threads (one in the DIY) section and it seemed that everyone raised the car, removed the wheels, installed the shock tower brackets, put the wheels back on lowered the car to the ground, THEN installed the bar. If I'm reading the above install tip correctly, the whole install should be done with the front end off the ground. Am I reading that right? Plus I'm not sure about the preload part. Can someone school me on that? Thanks!
2008 Toyota Yaris (Vios) 'S' sedan, Flint Mica, dropped on TRD springs, TRD anti-sway bar. Tinted rear windows. Lenso Samurai SC02 hyper black 17" x 7" rims, wrapped in 205x40x17 Federal ss595's. Color matched eyelids. Vios badge. Body color trunk trim (was chrome). Lamin-X tint on rear tails. Custom center exit exhaust. Tanabe front strut tower brace. |
03-23-2010, 08:59 PM | #2 |
Drives: 08 Yaris Sedan Join Date: Oct 2008
I installed mine on the ground without a jack and drove it home when i got home i jacked it up and preloaded the bar and put it back down. Drove it again afterwards there was a noticible difference on really sharp lane changes.
Only needs to be off the ground when you adjust the red bar and set it in place to tighten.
03-23-2010, 09:59 PM | #3 |
Drives: 07 Yaris Turbo Join Date: May 2007
I believe this only applies to bars with adjustable tension like the Tanabe. Straight bolt-on bars (like the Ultra Racing one) can be just bolted on with the car down.
03-24-2010, 12:08 AM | #4 |
Thanks Gents! It is done. I did the whole install with the front end in the air. I'm sure my car is faster now! Tomorrow may be the test. I have some great curves to try it on if traffic allows. I used Loctite Red on the threads of the shock tower bolts/nuts. I don't want those to loosen up. They were a pain in the a$$ to reach and tighten down with the 14mm socket I had. Perhaps an off-set open headed wrench might have worked better. I'm not sure if I just made that name up or not. Anyway, if nothing else the bar helped dress up the engine compartment.
Thanks Garm for the prompt service, as always.
03-24-2010, 02:01 PM | #5 |
Drives: yaris Join Date: Sep 2009
tanabe bars... great stuff... post pics!
03-24-2010, 02:33 PM | #6 |
I'll try to snap a pic later today and post it. It was dark by the time I was done last night.
03-24-2010, 02:44 PM | #7 |
loctite red = baller!
03-24-2010, 09:49 PM | #8 |
Here's two pics. The bar does sit pretty darn close to the negative battery post, but it has to be low for the hood to close without touching the bar. I was not able to pitch it through my favorite corners today. Too much traffic!
03-24-2010, 10:38 PM | #9 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
Have fun removing the negative terminal! I have to unbolt the driver's side and loosen the passenger side, raise the bar, and then remove the negative terminal. Loctite Red!!!!!!!!!!!? Not planning on removing the bars, ever? hehehe. On a Loctite 242 blue on some bolts on my front doors for the window mechanism. I'm tired of the windows becoming misaligned.
03-24-2010, 10:45 PM | #10 |
The brackets are there for good! Now I know a guy at a muffler shop that could cut them off for me if it ever comes to it. Thankfully the bar is easy to remove as needed.
03-25-2010, 03:27 AM | #11 |
oh, hahaha. That's cool. We used those lock-washers when we installed mine.
06-03-2010, 02:34 AM | #12 | |
Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
I hope the guys at Tanabe installed it this way on my Yaris during the R&D session. How can I tell if it was installed this way vs. w/ the car on the ground? |
06-03-2010, 10:35 AM | #13 |
I don't know that you could tell just by looking at it. If in doubt, remove the bar, then get the front end of the car off the ground and reinstall the bar. If the bar goes back on without having to adjust it, then I would say it was installed with the front end in the air. Anyone feel free to correct me if my logic is flawed it's still early and I haven't had a full cup of coffee yet.
Similar Threads | ||||
DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
FS: Yaris Liftback Strut Front Tower Bar | Treyz | Items for Sale by private party | 7 | 03-01-2009 10:00 PM |
TANABE Sustec Front Strut Tower Bar 07+ Toyota Yaris | StumpS | Items for Sale by private party | 6 | 02-15-2009 12:50 PM |
2001 Toyota Vitz RS Front Strut Brace | mistervitz | General Yaris / Vitz Discussion | 7 | 10-23-2008 12:36 PM |
C-ONE Front Strut Tower Bar - Installed & Impressions (Pics to Come) | bigsky2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 01-10-2007 06:53 PM |
