Old 05-10-2010, 09:47 AM   #1
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
How long does the Stock battery last ....
Almost exactly 4 years from the date of purchase .
I bought my Yaris in May 2006 , and my battery just died yesterday while attending the Shaw AFB airshow .
Old 05-10-2010, 09:57 AM   #2
RedRide
RedRide's Avatar
Although a car battery's life span is dependant on a few variables, a 4 year battery life is about averags.
I usually replace a battery when it get to be 4 years old or so because experience has told me that its days are numbered at that point.
I do a lot of night driving and the last thing I need is to get into my car at 2:00am and have a dead battery.
Old 05-10-2010, 10:10 AM   #3
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
Mine died shortly after 2 years of age.
My fault tho, I accidentally ran it dry a couple of times (radio on while detailing)
DFA is offline   Reply With Quote
Old 05-10-2010, 10:21 AM   #4
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
4 years is outstanding for a standard car battery!
Old 05-10-2010, 12:18 PM   #5
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
For those that still have stock battery . Here are some of the warning signs that your battery is going to die soon . At least these are some of the thing I noticed .
1. Your car takes a couple of extra seconds to crank .
2. Your car will NOT continue to crank if you release the key .
3. Your headlights dim when u go into nuetral .
Its odd. Before the show my GF asked what took Coryn so long to crank ? I replied " She is gonna need a new battery soon" . Sure enough , 5 hours later I'm pushing Coryn so my GF could perform a "roll crank" in second gear .
Old 05-10-2010, 12:20 PM   #6
STC
"LibertyRides!"
STC's Avatar
The last time I replaced a battery was for my old car (Pontiac Sunfire,1996) in early 2000. I got around four years of life with the original GM battery. I replaced it with a heavy duty battery. Sold that car in December 2009... the battery was still fine.
I'm shooting for 4 years. After that, I'll replace it with a heavy duty battery and hope it lasts for 10 years? I live in PA and the Winters can get a bit rough at times!
~ Mark ~
Old 05-10-2010, 12:35 PM   #7
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I was able to get 3 years out of the stock battery with my 600 watt RMS stereo.
Old 05-10-2010, 04:08 PM   #8
BLH
Drives: 2007 Yaris Sedan
My stock battery has a set of indicators on it.
Does anyone know if they actually can predict things.
One is needs water and the other one is need a charge.
Mine is just three years this month.
Now I did have a bad experience with one in my old Escort. Must have been low on water and gassing. Went to start it and it must have sparked between the plates. Yes it exploded splattering acid all over the place.
Old 05-10-2010, 05:44 PM   #9
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
All I did was add water .
Old 05-10-2010, 06:53 PM   #10
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
Our Yaris was purchased May 2006 and has 93k miles on it. Stock battery still provides plenty of juice. I even run the radio for an hour every work day during lunch.
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline   Reply With Quote
Old 05-10-2010, 07:37 PM   #11
bronsin
bronsin's Avatar
Hmm 2001 ECHO got seven years out of it.
Old 05-10-2010, 10:32 PM   #12
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
2004 Ford Ranger. OEM battery still going strong.
Reddog99 is offline   Reply With Quote
Old 05-11-2010, 11:38 AM   #13
POORSHA
POORSHA's Avatar
Drives: 2008 LB
Almost 2 years to the day, Replaced with yellow top
POORSHA is offline   Reply With Quote
Old 05-11-2010, 11:55 AM   #14
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I had 6 years on an optima blue top once... and it was still doing awesome... course I also had a 160amp alternator.... that battery rested at 13.4volts (car turned off) I think the main thing that determines how long a car bat will last is how much electrical strain the driver puts on the battery... Sure I had 2000watts of stereo... but I babied that battery... let it recharged before and after running my stereo... make sure I never turned the car off with the batt not fully charged.
Got 2.5years/47,000 mile on the stock bat right now... no intentions of replacing it any time soon.
Old 05-11-2010, 06:31 PM   #15
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
163,000km and 4 years and no problems yet.
devinlamothe is offline   Reply With Quote
Old 05-12-2010, 12:50 PM   #16
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
i have 4 years and 55000 miles on my stock battery so far, and it is running strong.
Waiting for it to die before i buy a lightweight one.
Colin Chapman disciple
Old 05-12-2010, 04:17 PM   #17
swidd
Drives: Yaris HB
How do one go about adding distilled water to the stock battery? There's quite a few plastic screws on the top, does it matter which one I put water into? Or do I have to put it into all of them?
Old 11-10-2010, 09:37 AM   #18
RobinNJ
Drives: Yaris coupe
I have a 2007 Yaris coupe and I am now experiencing a really slooooowww crank, then it starts. I tried to see if the lights dimmed in neutral, partially turned the key, but nothing different happened. Half turn still starts the car and completes the ignition, it's just that it is chugging slowly to start? I can think of only three things: battery, alternator, or starter motor as the problems. I have 67k would the alt and the starter still be covered under warranty? I mean, 3 yrs and the alt or starter goes?
help in NJ
RobinNJ is offline   Reply With Quote
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
How long does the battery in the remote last? yaris-me General Yaris / Vitz Discussion 18 01-31-2010 01:44 AM
Fog lamps as back up low beams. ellenbetty General Yaris / Vitz Discussion 114 10-22-2009 03:40 PM
simota or stock? JapRulezz Performance Modifications 20 03-04-2009 07:52 PM
looking to buy or trade for stock exhaust shinlee Items for Sale by private party 9 12-11-2008 04:31 PM
