Old 05-18-2010, 12:14 AM   #1
kngrsll
Apexing Egg!!
kngrsll's Avatar
Roll bar Installed
So we made a roll bar per the NASA rules for TT. turned out pretty nice
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 05-18-2010, 08:41 AM   #2
nemesisz
559 Before the Hack
nemesisz's Avatar
Drives: 07 Yaris LB
Nice roll bar.
Did you scale your car for before and after weight? I am just curious about the weight. Also can you tell us about the specs for the materials (tube diameter and type)?
Do you have any additional pictures like the mounting plates and weld quality?
One final question, is the diagonal bar on the main hoop one piece? Can’t tell because of the lighting in the picture.
Sorry of the 20 questions but I have been researching roll bars and cages for a few weeks now.
nemesisz is offline   Reply With Quote
Old 05-18-2010, 10:17 AM   #3
If you guys did all the bending yourself, you should have built it a lot wider and higher. There's too much crush area between the body and the cage to be as effective as a roll bar should be.
In the event of a side impact, the car would crush into the seat before it hits the bar. Same applies in a roll over.
Old 05-18-2010, 10:30 AM   #4
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
yea i was thinking the same thing, it should be a tight fit, could just be the angle of the photos though
http://www.4055design.com
Old 05-18-2010, 12:20 PM   #5
Those are teaser pics --- details!!!
also, is it not attached to the B pillars?
Old 05-18-2010, 01:07 PM   #6
Jason@SportsCar
I agree. I also would not like having that tube right behind my head/seat. Proper aligning of the harness, if one is going to be used, could also be a challenge with the down tube being behind the seat.
NASA 11.4.7 Roll Bars
All open cars should have a roll bar installed to help protect the occupant(s) from injury
during a roll-over. The roll bar should be able to withstand the compressional forces
involved in supporting the full weight of the car. The roll bar’s main hoop should extend
the full width of the car (except certain cars that have been approved by NASA).
The
main hoop shall be one continuous piece with smooth bends and no evidence of
crimping or wall failure shall be present (i.e. should be Mandrel bends). All welds should
be of the highest possible quality, with full penetration [Ref:(15.6.15)]. All cars with roll
bars are required to have adequate roll bar padding per CCR section #15.6.4. In cases
where the driver’s head may come in contact with the roll bar should the seatback fail, a
seatback brace is required in conformance with section #15.6.22. The material and
minimums are as follows: (All cars with full roll cages should conform to the applicable
sections found in section #15.0.)
Old 05-18-2010, 02:14 PM   #7
id3379
§†ęĄ¶‡Ћ-NCP96
id3379's Avatar
looks awesome, i want one now :D
id3379 is offline   Reply With Quote
Old 05-18-2010, 02:25 PM   #8
kngrsll
Apexing Egg!!
kngrsll's Avatar
I dont know what to tell you guys, i dont build cages.
the bar isnt anywhere near my head, the harness bar lines up right behind the slots in the seat per the rules for the harness.
i would have thought the bar would be closer to the B pillar as well, but he did not like the way that would mount to the chassis. The roll bar is outside my shoulder when I am in the seat, the left upper "wing" of the seat sticks out a little bit.
its certainly better protection than it was, im not going to argue cage design though as i dont know much on the subject, hence having my cage built for me. this guy has built lots of cages for local cars that have competed for years in SCCA and NASA events. the purpose of the bar is serve as protection in the worst case scenario while on track while retaining some streetability since it is still a daily driven car.
Old 05-18-2010, 02:26 PM   #9
kngrsll
Apexing Egg!!
kngrsll's Avatar
i think that becomes an additional points penalty for doing so...
Old 05-18-2010, 02:29 PM   #10
kngrsll
Apexing Egg!!
kngrsll's Avatar
Originally Posted by nemesisz View Post
Nice roll bar.
we didnt weight it before and after, no scales.
I would have to ask what tubing he used, he took care of all that.
ill get pics of the lower mounts.
The diagonal bar is one piece because the rule book states it must be. the harness bar is two pieces.
Old 05-18-2010, 03:00 PM   #11
kou
Drives: 08 lb
looks good.
Tamago's guide to ultimate yaris handling Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 98 02-18-2024 05:45 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
Installed TRD Strut + Sway bar Blenjar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-10-2007 11:46 PM
