Old 04-16-2006, 10:42 PM   #1
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
Yaris wheel sizes and XA (ist) wheel sizes
does anybody know if you can fit the same size wheel and offset from an XA car to a yaris?
this question is more related to aftermarket wheels....and US members of the forum ;)
Master is offline   Reply With Quote
Old 04-17-2006, 07:40 AM   #2
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
they should be the same sizes, the suspension is different, so the offsets might be off, but a test fit will tell you if they do or not.
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Old 04-17-2006, 09:41 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
The stock offsets are the same. The bolt pattern is the same. The stock 15" wheels and tires are the same.
Old 04-17-2006, 12:26 PM   #4
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
thanks for your help guys.
xa's can run a 35 offset...wow think of the dish on wheels
Old 04-17-2006, 01:04 PM   #5
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
xAs can run more than that. +35 is only 3mm difference than the stock offset. On my xB, I'm running a +20 in the rear, +35 up front.
Old 04-17-2006, 01:27 PM   #6
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
^^^ what wheel size are you running? it sounds like 15 or 16
Old 04-17-2006, 01:45 PM   #7
Thirty-Nine
16x7
Old 04-17-2006, 06:35 PM   #8
why?
why?'s Avatar
Drives: Yaris LB
Why are they different offsetts? Is thier any reason?
Old 04-17-2006, 07:13 PM   #9
Master
Hella Smart
Master's Avatar
Drives: Lexus IS300
most likely due to it is the outside fender placement
Old 04-18-2006, 11:35 AM   #10
Thirty-Nine
The xB has a wider track in the front. Adding +10mm to the rear track evens things out. I added 5mm more to the rear because I like the looks.
Old 04-18-2006, 11:38 AM   #11
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
I think 16x7 looks killer on the xB.
If I go bigger than 15 eventually, I think that's what I'll do. Good compromise between looks, handling and weight.
Idjiit is offline   Reply With Quote
