Old 07-18-2010, 12:59 PM   #1
salmonz
salmonz's Avatar
Drives: 07 Yaris Sedan
New brakes/rotors - sounds like metal on metal rubbing
A few weeks ago I changed my front stock toyota brakes/rotors on my 07 yaris with premium semi-metallic and premium slotted rotors. I installed the shims on the brakes so I don't have squealing.
The problem I have is when I apply the brakes, I hear a metal on metal rubbing (no squeal) coming from the brakes/rotors. I've driven about 500 miles already, mostly highway driving.
What can I do to stop the metal on metal rubbing and have smooth braking without noise?
Thanks
salmonz is offline   Reply With Quote
Old 07-18-2010, 01:43 PM   #2
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i think it had something to do with semi metallic pads...may last longer but annoying sound you may have...
Old 07-18-2010, 04:29 PM   #3
salmonz
salmonz's Avatar
I didn't have the problem with the toyota semi metallics, or does the toyota stock pads have some ancient japanese secret that kept them smooth and quiet?
Old 07-18-2010, 05:52 PM   #4
detroiter
detroiter's Avatar
Did you clean off the brake pads with Break Clean? Helps big time with quieting down pads until they break in.
Old 07-18-2010, 06:38 PM   #5
yarrr
Drives: 07 sedan
What brand of pads? Some pads require a bedding in process. Other than that pull them apart and take a look, you might have dropped a tiny rock or piece of metal in while you were changing them.
Also, have you checked the rears? Sometimes the rears sound like they are coming from the front.
Old 07-18-2010, 07:42 PM   #6
salmonz
salmonz's Avatar
Yes, did this during the install. I also applied some red CRC disc brake quiet within the shims. What I didn't do is lightly sand down the surface of the rotor and pads.
Here's the rotors/pads I got:
http://cgi.ebay.com/ebaymotors/ws/eB...ht_4587wt_1002
Old 07-18-2010, 07:44 PM   #7
salmonz
salmonz's Avatar
Haven't checked the rears but it did sound like it was coming from the front.
Here's the front pads/rotors I purchased:
Old 07-19-2010, 08:56 AM   #8
PhillyG
Drives: 2009 Yaris
did you apply brake grease to the pins and slide after cleaning them?
PhillyG is offline   Reply With Quote
Old 07-20-2010, 12:20 AM   #9
salmonz
salmonz's Avatar
No I didn't. I moved them in and out without removing them and they seem to move pretty smooth. Should I do it anyways?
Old 07-20-2010, 08:46 PM   #10
PhillyG
Drives: 2009 Yaris
i do.. but its personal preference.. i ALWAYS do it for the customer.. worth the extra five mins for no comebacks. has been known to cause squealing and groaning if slightly less than stellar.
Metal on metal rotating wheel noise phyrefighterjay General Yaris / Vitz Discussion 7 04-19-2010 11:31 AM
