Old 12-04-2006, 11:29 PM   #1
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
DIY - Change your Gauge Cluster Color (Sedan)
Description:
To change every none-white indicator light to either white or blue.
****The backlighting to the Speedometer and Tach use a piece of "smoked plastic/acryllic" to spread the light of serveral LEDs across the face of the speedo and various parts of the cluster, meaning any replacement color would be slightly "smoked" or slightly darker then the attended output color. My theory is that if you use a higher output LED then you could offset the "smoke".
Tools Needed:
- Philips head screw driver
- Hands
- Soldering Iron (with small tip)
- 30 New LEDS’s
*** I ordered these White LEDS - http://www.eled.com/product.asp?cata...EPT2012RWF%2DA (replaced stock white with theses; not necessary)
*** I ordered these Blue LEDs - http://www.eled.com/product.asp?cata...=EP2012PBC%2DA (replaced all non-white with these; well until i ran out :-) )
- Extra Solder
- Needle nose pliers
Instructions:
1. Remove outer “molding” around stereo and guage cluster
2. Remove both sets of wire’s going to gauge cluster, then unscrew two screws holding the gauge cluster
3. Bring the cluster indoors to a static free environment (or have a static wrist band).
4. Flip over the guage cluster, unscrew the 3 screws, then pop the black tabs, remove white backing
5. Remove “raised board,” lift+pull straight out
6. Flip over gauge cluster, and then pull out the “gauge needles” (pull from base of the needle;the round part, they are on tight, but will come loose)
7. Admire the bare circuit board :drools:; take note of the LED positions
8. Use pliers and “grip” middle of OEM LED, use the soldering iron in other hand and heat up one point of the LED solder point and then lift with the pliers on that side of the LED, after one side is free heat-up the other side of the LED and lift the LED off the board.
There is an arrow at the bottom of the LED point the arrow in the same direction as the arrow on the circuit board and re=solder the LED (please Google “how to solder” if you are not familiar with soldering) (x30ish)
9. After repeating step 8 on all LED colors that you wish to change, then reverse the steps to put back together the Gauge Cluster (make sure you put the longer gauge needle on the speedometer)
hope this helps
will work for parts
Old 12-05-2006, 06:36 AM   #2
vodkalush
I drive a yarrrris
vodkalush's Avatar
will work for parts
Old 12-05-2006, 07:11 AM   #3
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Sweet!
Did you have any trouble getting the needles put back on correctly?
Old 12-05-2006, 07:14 AM   #4
Violin
Violin's Avatar
What LEDs did you use? Where did you get them?
Old 12-05-2006, 07:26 AM   #5
vodkalush
I drive a yarrrris
vodkalush's Avatar
edited first post to include LEDs; I'm also going to work on labling the circuit-board picture with a "layout map," that that prob wont happen until the end of the week.
will work for parts
Old 12-05-2006, 07:29 AM   #6
vodkalush
I drive a yarrrris
vodkalush's Avatar
Originally Posted by Violin View Post
Sweet!
nope, they slip right back on, when you plug the cluster back in (well atleast mine seemed to) the needles seem to "re-align" themselves
will work for parts
Old 12-05-2006, 07:32 AM   #7
vodkalush
I drive a yarrrris
vodkalush's Avatar
if anyone does this and only has a speedometer (no tach) but notices that they have 2 of these (pic below) please PM me.
will work for parts
Old 12-05-2006, 09:07 AM   #8
punch
punch's Avatar
guess chino owes you some booze!
Old 12-05-2006, 12:11 PM   #9
Violin
Violin's Avatar
Thanks for this vodka - I hope the hatch is similar.
What soldering iron do you use for this work?
Old 12-05-2006, 01:39 PM   #10
vodkalush
I drive a yarrrris
vodkalush's Avatar
some cheap-o radio shack one; however now thinking about it, I did use a small tipped soldering point.
1st post updated.
will work for parts
Old 12-05-2006, 04:33 PM   #11
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
Perfect!
Wish I could find a DIY for mine!
Old 12-05-2006, 05:01 PM   #12
vodkalush
I drive a yarrrris
vodkalush's Avatar
the design shouldnt have changed that much from the 06-07.... and there really shouldnt be a real difference between the LB and Sedan (other then physical size), takeing apart the whole thing (include car removal) should take maybe 10-15mins. I say give it a shot.
will work for parts
Old 12-05-2006, 05:30 PM   #13
Katana
Katana's Avatar
Thanks for anwsering!
Well, the thing is that mine is digital!
Old 12-05-2006, 05:41 PM   #14
vodkalush
I drive a yarrrris
vodkalush's Avatar
well you know that means that you could change the "backlighting" of the digital read outs (a pic would help), I'm gonna take a guess and say that the construction of the housing is similar but the amount of soldering will go up drasticly (the sedans intergrated LCD uses 32 LEDs and its only somthing like 3x5inches (or somthing like that) )
will work for parts
Old 12-06-2006, 12:48 AM   #15
paultyler_82
There is a big difference between LB and Sedan, the Sedans use standard LED backlit gauges like the celica, the LB's use Optitron, which, as I understand, is high contrast white LED's behind layers of colored and smoked acryllic. As for the Digital readouts... you might try disassembling your cluster and attaching colored celophane paper to the segment LEDs underneath, this is what i30 and Maxima people do to change the digital displays on thier radios, A/C's, and clocks.
Old 12-06-2006, 03:24 AM   #16
Katana
Katana's Avatar
I am planning on disassembling the panel, to figure out what's behind.
Old 12-06-2006, 06:21 AM   #17
vodkalush
I drive a yarrrris
vodkalush's Avatar
well as far as the speedo-tach-and "backlighting" then the sedan is the same way, I wasnt interested in chaning the backlighting (just the gauge cluseter indicators) but, you could change all the LEDs; which include the lighting to the smoked arcyllic (it seems to use what I'm gonna call "light tubes" to lite the acryllic) if you change the "backlight color" the outcome will be a slightly darker color then what you buy; so if you get a "high intensity" LED you might be able to make up from the "smoke"
edit:
but then again the only way to know for sure is to have someone with an LB take apart their gauge cluster to see just whats there (a posted pic for verification would be flipp'n sweet)
will work for parts
Old 12-06-2006, 06:30 AM   #18
vodkalush
I drive a yarrrris
vodkalush's Avatar
I have updated some information in the first post.
will work for parts
DIY - How to change you stock radio color vodkalush DIY / Maintenance / Service 70 09-13-2012 10:32 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 08:37 PM
Gauge Cluster Color Changed (PIC Inside) vodkalush Cosmetic Modifications (Exterior/Interior) 11 12-04-2006 08:48 PM
Change the Console Control/Shifter Color Ayka Cosmetic Modifications (Exterior/Interior) 1 09-28-2006 11:21 AM
