#1 |
DIY: Heated Seats for 2006-2011 Yaris
Attached is my DIY for installing seat heaters on a 2006 to 2011 Yaris. The DIY includes installing and wiring the seat heaters both with aftermarket seat covers and under the OEM seat fabric.
I installed a set (both front seats) in my 2009 Yaris Liftback, under my Clazzio leather seat covers (purchased from MicroImage). This installation was incredibly easy and would have been even easier if I was installing the seat heaters and seat covers at the same time. I also installed one seat heater on Crashy's OEM driver's seat (2008 Liftback) under the OEM fabric. Fortunately, as a budget car, the Yaris seats are quite simple, so removing and reinstalling the OEM seat fabric was not difficult. I have not removed the OEM seat fabric on a Yaris with the side airbags in the seat, so I would not recommend doing so. For seats with side airbags, I would recommend using seat cover like the Clazzio ones (which are designed to be used with seat mounted airbags). The other option for airbag equipped seats would be to install a single pad style seat heater, where just the lower cushion receives the heat pad. The power circuit used in my DIY is more than capable of supplying power to four or five seat heater kits, should you choose to also outfit the rear seat. My kids are arguing that it is unfair that my wife and I have heated seats and they do not, so I believe that I will soon be adding rears to my installation to prevent a mutiny. I purchased my seat heater kits from http://www.warmseats.com. Upon receipt I was very impressed with the quality of the pads and the wiring harness, so I would definitely recommend them to others. As a final note, you will notice in the DIY the significant rust on the OEM seat which I perform the under OEM fabric installation. If you are wondering how a seat frame gets this rusty; It was Crashy's seat. After her demise and before I bought her, she spent over a year parked outside with all but her left rear window missing. There was actually moss growing on the front seats. Yaris - Seat Heater Installation.pdf .
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
SWEET! CTScott, you are freaking awesome!
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#3 |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
CTScott, you are truly a great asset to the Yaris community and your efforts are very much appreciated. Thanks for everything you do!
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
#4 |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
+3 thanks for being so awesome!
#5 |
![]() ![]() Drives: '07 Yaris 5dr HB Join Date: Aug 2010
Wow! Excellent write-up! You da man CTScott! I sure hope this has been stickied!
#6 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
A+ Write up yet again Scott! This definitely needs to be stickied.
#7 |
![]() ![]() ![]() Drives: yaris1.33 Join Date: Jul 2010
scott you are sick
is something you can't do ? :) great stuff you are posting here thanks |
#8 |
![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
As always Scott, you rock! Do you have any pics of the OEM seat covers finished with the heating pads under them? I'm curious if you can see the heating pads under the OEM fabric or not. I don't see foam on the backside of the OEM fabric, so it makes me think you can see the marks where the heat pads are at.
#9 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I'm still kinda grossed out by using seats that had moss growing on them,lol
Seems kinda......squishy |
#10 |
I was pretty grossed out myself, but I was amazed as to how well they cleaned up. The car also had a couple of inches of water on the floor, when I went to pick it up, and the spare tire well was completely full. The amazing thing with the seats is that the foam did not actually soak up the water, as opposed to the carpet and the thick sound isolating padding that was under some areas of the carpet, which were completely saturated.
#11 | |
#12 |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
2-3 minutes warm-up time. How much do you estimate you spent in parts all said and done? I'm wondering if it is worth it, seeing as the Yaris gets warm quickly and my tolerance for freezer-burn pain is quite high...
#13 | |
With the 2-3 minute warm up, that is very similar to the heater coming on, and I really had no interest to putting one in for myself, but now that I have it, I can wait to go out in the car. There is such a difference in directly heating your buns and back, as opposed to having dry hot air blowing on or around you. I could drive with my moon roof open on a below freezing day now.
#14 |
Mr. 155 and climbing
Drives: Seriously Modded 07 Sedan Join Date: Jun 2006
Scott,
I have been pulling out my hair trying to find a 20 Amp relay along with the socket like you used. I went to AutoZone, O'Reillys, CarQuest, and another auto parts and wasted 3 hrs to no avail. Can you assist? Also, none of them actually carried a 18-22 AWG top splice either....please help me not waste another evening getting nothing accomplished! Thanks mang!
Team Tiamat Racing on Facebook Youtube Channel: Team Tiamat Racing Class record holder in Land Speed @ 154.5mph for 1.5 mile and 145.5mph in the mile in the F (2.016 to 3.014 L), G (1.524 to 2.015 L), and H (1.016 to 1.523 L) classes. |
#15 | |
http://www.autozone.com/autozone/acc...er=437420_0_0_ Here's the 18-22 AWG tap splice (the red one in this kit of three): http://www.autozone.com/autozone/acc...er=421789_0_0_
#16 | |
Ouch...they are showing nothing below 22 bucks per relay for some reason...the 40 amp that you link to they want 30 bucks...not sure that I want to swallow that type of investment on the relay, but then again it is much better than a dead battery possibly. What about the socket though?
#17 | |
http://www.radioshack.com/product/in...LAID=145898269 Typically, places that sell them will also have the harness or socket for them. The other option is to use fully insulated female spade connectors, if you can't find the harness. I bought a bunch of relays and sockets a while back for doing remote starter installs. I remember paying about $4 each for the relays and less than $2 each for the harnesses. Here's a place selling the harnesses for $2: http://www.allelectronics.com/make-a...RELAY/-/1.html
#18 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
epic write up. this is beautiful. this should be a sticky. i will be trying this for next year (mine has seat airbags but i gonna try it anyways)
| Tags |
| diy, electrical, heated, heaters, seat |
| 2011 Yaris...A few questions | SkeletorSeatbelt | New YARIS Purchase Forum | 0 | 08-16-2010 09:42 PM |
| US-Spec Yaris Seats | OKJeeper | General Yaris / Vitz Discussion | 8 | 02-02-2006 08:27 PM |
