Old 12-03-2010, 10:35 AM   #1
henry33
Drives: yaris1.33
what is behind the instrument panel
maybe somebody have picture of dismantling the instrument panel since I need to see whether the heating which is going on the windshield is accessible when I dismantle the instrument panel ?
I am asking because now when the temperature dropped below zero the heating went is rattling :(
thanks
henry33 is offline   Reply With Quote
Old 12-03-2010, 12:25 PM   #2
If you remove the cluster, the center vent duct is under it. Once you remove that (it just snaps into place), you have a nice view into the top of the airbox. In this picture the top of the dash is removed, so you can see more than you will see with just the cluster removed:
Old 12-07-2010, 01:00 PM   #3
henry33
Drives: yaris1.33
great
thanks scott
Old 12-10-2010, 09:16 PM   #4
Revsson
How much room is there between the vents and the piece right in front of the IP?
(If I wanted to install something in or under that panel right in front).
DIY rear Interior panel removal 09 3dr LB bkndacn Cosmetic Modifications (Exterior/Interior) 10 03-11-2013 01:05 AM
Instrument Panel Light out? ApolloX DIY / Maintenance / Service 2 09-28-2010 05:56 PM
Instrument Panel goes out if I turn on my lights ceceb DIY / Maintenance / Service 9 07-08-2010 05:56 PM
Question about replacing Instrument Panel!! Wowzers78 General Yaris / Vitz Discussion 0 03-18-2010 09:25 AM
New instrument panel fmicle DIY / Maintenance / Service 17 07-19-2009 09:09 PM
