Old 12-17-2010, 03:38 PM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
check out these horns
hey guys take a look at these i think they'll sound a lot better then the stock horn. can anyone tell me if this is an easy install i assume it is just not sure what to do with the relay it comes with will i have to splice wire or something?
thanks guys and or gals
Old 12-17-2010, 09:34 PM   #2
If the combined current draw for the two horns is less than 10 Amps, you can skip the relay and wire them both to the existing horn wire (which is the positive feed) and then you bolt the tab on them to metal as the ground.
If the current draw is more than 10 Amps, then you have to use the included relay to switch a fused feed from the battery.
Old 12-18-2010, 03:46 AM   #3
matthewai
matthewai's Avatar
oh cool i see i think they are 12v so ill prob end up doing it the second way thanks alot ill update when done
Old 12-19-2010, 02:15 AM   #4
yaris2010RS
yaris2010RS's Avatar
i actually LOLD, lol
volts and Amps are very different things. lol
i personally say try them on and if it blows the fuse then bother with the relay
Old 12-19-2010, 06:15 AM   #5
If you look at the specs for them, they draw 12A @ 12V.
Old 12-19-2010, 10:31 AM   #6
nemelek
DWEED
nemelek's Avatar
I need to get a louder horn.
Old 12-19-2010, 10:58 AM   #7
coheed
Drives: 08 BB LB
Eh.... those are weak, go with a setup like this. Its about 130dB's. Sounds like mini train.
Old 12-19-2010, 11:33 AM   #8
I've been trying to decide on what to go with for a while. After looking at and listening to a bunch of different ones I have it narrowed down to the Stebel Nautilus or TMS80
http://www.stebel.it/stebel2009/prod...tipologia=auto
Old 12-19-2010, 02:36 PM   #9
matthewai
matthewai's Avatar
ahhaha yes i did not fully read and process scotts reply ill have to check the box for amps not volts
Old 12-19-2010, 03:59 PM   #10
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Coheed...
Yeah baby! Now, stick those horns in the back bumper facing down to the ground for the best sound pressure distribution...
Of course the little camera mic doesn't do it justice...
― Thomas Paine
Old 12-19-2010, 06:39 PM   #11
I was giving you the benefit of the doubt on that, since I checked Hella's website and saw that the pair actually draws 12 A. So, the relay will be necessary.
Old 12-19-2010, 07:06 PM   #12
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I have learned now that I am living in Alabama I had best invest in a horn upgrade.
Old 12-19-2010, 08:41 PM   #13
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I did the Hella three tone electric air horns...and it still isn't enough! I need one of those HornBlasters pieces but I refuse to give up (more) space in my trunk...so I'm stuck.
― Thomas Paine
Old 12-19-2010, 08:44 PM   #14
The train horn on the truck in your video sounds awesome. You just need to do an airbag suspension so you can justify the space for a compressor and put that same setup on your car.
Old 12-20-2010, 02:12 AM   #15
sqcomp
Roadrunner Jr.
sqcomp's Avatar
I've got too much "junk" in the trunk. No pictures until May, but trust me...too much going on.
― Thomas Paine
Old 12-20-2010, 07:05 PM   #16
JetfireK
Drives: 2008 3 Dr Liftback
AIR HORNS FOR YARIS....JUST A THOUGHT....
You can buy HAND HELD AIR HORNS at any boating store. Might not be dandy in the rain...but they are LOUD...LOUD...LOUD...Maybe cost 10 dollars or less...Your passenger can hold it and blast as you go past.....
JetfireK is offline   Reply With Quote
Old 12-20-2010, 08:34 PM   #17
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Those are fun indeed. In a past job, I snuck up on a shoplifter who has just left the store loaded...I came up right behind him and BLASTED that compressed air horn...he actually pissed his pants. I love that work, just doesn't pay for $hit taking into account the risk.
― Thomas Paine
Old 12-24-2010, 08:21 AM   #18
matthewai
matthewai's Avatar
so i understand ill prob have to use the rely where exactly does it go? in the fuse box? do i have to switch it with a stock one or it just goes in on its own? thanks
hella, horn, tone, trumpet, twin
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine Light Question falkor_99 General Yaris / Vitz Discussion 11 07-22-2007 05:15 PM
Paying for the Yaris with a check? YotaYarisUSA New YARIS Purchase Forum 15 07-11-2007 03:31 PM
