Old 03-26-2011, 08:27 AM   #1
dbudworth
Drives: '09 Yaris,Sedan,1.5L,Manual
Pulsating Vibration
My ’09 yaris sedan has a pulsating vibration only in 5th gear going 60-65mph (2500-2800 RPM) range.
I thought I saw a TSB on some kind of vibration before but now I can’t find it.
When I push the clutch in, the slight vibration goes away. So it isn’t an off balance wheel or a bad tire. I’m thinking it has to do with the engine or transmission, since it goes away when the car is in neutral. The vibration is present on acceleration and deceleration.
Anyone have any ideas as what would be causing the pulsating vibration. It pulsates about ever 1-1.5 seconds, very slight vibration that you can feel through the whole car. Not the steering wheel, but on the floor pans and seats.
Thanks in advance for any input. Its greatly appreciated.
dbudworth is offline   Reply With Quote
Old 03-26-2011, 09:32 AM   #2
swidd
Drives: Yaris HB
could be a natural harmonic? I don't know why you rule out alignment issue or tire balance.
Old 03-26-2011, 10:05 AM   #3
dbudworth
I ruled that out because it is related to RPM's. If I push the clutch in, the vibration goes away.
When I accelerate up to 70mph, the vibration is there, then push the clutch in and coast down to 55mph, no vibration. Speed back up to 70, vibration accelerating, keep the clutch engaged and cost down to 55, the vibration is still there.
Seems like a lot of other people are having the same problem. I found this thread after doing some more searching.
http://www.yarisworld.com/forums/sho...ight=vibration
Old 03-26-2011, 10:08 AM   #4
brg88tx
Drives: 07 Yaris Sedan, Auto
there has been a few threads on this. my 07 sedan does the same thing around 60 mph.
brg88tx is offline   Reply With Quote
Old 03-28-2011, 06:50 AM   #5
echaru
PsychMobile
echaru's Avatar
Drives: '10 Yaris 5Dr Blazing Blue
My car has the vibration too. I just ignore it after I realized that 60mph vibration comes standard with all Yaris.
echaru is offline   Reply With Quote
Old 03-28-2011, 04:06 PM   #6
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
+1. Normal engine harmonics. My Tanabe exhaust "fixed" mine!
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
2000 R.P.M Vibration dallas General Yaris / Vitz Discussion 34 05-16-2018 05:54 PM
steering wheel slight vibration high speed??? marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 10-01-2012 06:36 PM
How much engine vibration is normal? Frankd1 DIY / Maintenance / Service 6 10-14-2009 09:11 PM
A/C vibration from supercharged engine? Morgan Forced Induction Forum 16 08-01-2009 12:47 AM
Post-rotation vibration kurokoma-kun Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-15-2007 05:02 PM
