Old 04-30-2011, 10:15 PM   #1
Toy Box Racing Store
Drives: 1NZ-FE
On The Rise
This is Dustin from "Toy Box Racing" I am the one that has brought you the Ferrea Racing Valve system and have now teamed up with a partner who knows the racing industry extensively especially the 1NZ-FE motor. Together we will be bringing you fully built to order race motors for the 1NZ-FE.
We have the Exclusive on the valvetrain from Ferrea as well as we have now joined up with Junichi the owner of Jun Performance from Japan. We currently have 2 sets of racing cams coming in to do exclusive builds with.
Me and my partner have also got ARP doing a TBR exclusive head stud kit and have even forked out the dough of 3,500 to have Commetic make a multi layer steel gasket to turn up the boost to 30 psi.
We are also picking up where perrin left off with the fuel rail. A new one is going into production at Aerospace Components. This will also be a TBR exclusive. It will come in what ever color you like. It will have a optional return to tank line and a port for a guage as well as a black braided line to plug right in to the factory connection.
We plan to bring you the best the industry has to offer. No regrinds like some other companies, no imitation big bore T.B from the junk yard. We will bring you 100% quality USDM or JDM parts.
We will also have a motor exchange program available.
My partner who had great involvment with Brian Crower and Arias pistons will bring these parts to the table as well. You will like what we are going to do to the indust
Best Regards
TBR
Toy Box Racing Store is offline
Old 04-30-2011, 11:28 PM   #2
Ye-ha
Bluevitz-rs is offline
Old 05-01-2011, 09:11 AM   #3
Drives: 1NZ-FE
Here is the Valvetrain......pic
More to follow, Getting excited yet? You will be.
Old 05-01-2011, 09:33 AM   #4
Drives: 1NZ-FE
Perhaps this will get you going to!
Yes those are gas ported, ceramic coated pistons!
Old 05-01-2011, 10:06 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
-Type 07 FFL-
My odometer 03/11
mazilla is offline
Old 05-02-2011, 06:47 PM   #6
Viperoni
Drives: 2005 Toyota Echo
Good price on the valve kit!
2006 Saturn Ion Redline
Viperoni is offline
Old 05-03-2011, 10:54 AM   #7
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Originally Posted by Toy Box Racing Store View Post
The nitrous kit that fits and works!
Proton Series nitrous systems combine performance, durability and value in a compact and easy to mount module. Proton systems contain high quality, made in the USA, solenoids that are capable of producing 150 horsepower to the wheels. The black anodized aluminum housing not only looks great, it pulls heat away from the solenoids for extreme durability. This Proton Plus system includes jetting for 35HP, 50HP, 75HP, 100HP, 125HP and 150HP. This system also includes a 5lb nitrous bottle with an aluminum high flow Lightning 45 bottle valve, stainless bottle brackets, a single Shark nozzle, nozzle adapter, stainless braided nozzle lines, extra long braided stainless feed line, stainless fuel line, master arming switch, wide open throttle switch, 40 amp relay, relay harness as well as every nut, bolt and electrical connector needed to complete the installation. Fits all electronic fuel injected vehicles with a single throttle body.
"Nitrous Express solves another problem! Installing a nitrous system on a late model EFI vehicle can be a hassle if you dont have one of the new NX high flow Fuel Taps. These high flow adaptors make the chore of tapping factory fuel systems safe and easy. No cutting or drilling just a quick, easy install that takes only minutes and each high flow adaptor has dual outlets for multiple uses. Works on 3/8 & 10mm fuel lines
How big of a shot can a stock Yaris motor handle?
Flipper_1938 is offline
Old 05-03-2011, 11:07 AM   #8
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
35 IF YOUR BRAVE....
BLAZINBLUEVITZ is offline
Old 05-03-2011, 02:36 PM   #9
NX Proton kit at Summit $399.95: http://www.summitracing.com/parts/NEX-20421-10/
So you're charging $100 for a fuel fitting?
cali yaris is offline
Old 05-03-2011, 02:40 PM   #10
Astroman
Modded Moderator
Astroman's Avatar
In order to sell here you'll need to contact an administrator (vitzboy or yarisbeuller) to become a vendor. Its only fair to the rest of our vendors on here.
Astroman is offline
Noob on the rise... Blenjar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 01-11-2007 11:22 PM
