Old 11-29-2011, 02:48 AM   #1
Put-in
Drives: Yaris 1.0 2007
Yaris 2007, 1KR-FE valves knocking
After cleaning fuel injectors in ultrasound bath I experience valve knocking in interval 2000-2500 revs when it's slight uphill. I assume that car don't have enough fuel in that moment bcs when I add gas knocking stops.
knocking is more noticeable when engine is hot.
So, just after fuel injectors are cleaned that knocking started, with same fuel before it was not a problem. Now is 95 octane fuel, and still knocks.
It's really annoying, can someone help please?
Put-in is offline   Reply With Quote
Old 12-04-2011, 09:28 AM   #2
One can only guess that your injectors are now clogged and not delivering enough fuel causing a lean condition and thus the knocking you're hearing.
Old 12-06-2011, 04:00 AM   #3
Put-in
I have solved a problem. The problem was in wrong oil. It was 10W40, instead 5W30. I just have changed oil and all sounds have disappear :)
