Old 12-12-2011, 02:44 PM   #1
A-Dingo-Ate-My-Baby
Drives: yaris
Torque wrench on lugs is critical on the Yaris
critical, because over-tight can induce warping as I found
I had slapped on my winter rims with 'pretty dang tight' and no torque wrench,
and all is fine and everything seemed OK.
a little bit when braking, I felt a thumping...Oh no....warped rotors...no way
did I overheat these things....I mean...really ????
anyhow, finally I dug out the digital torque wrench and retorqued all
my bolts to 76 foot pounds.
a) I found my human-gorilla torque was around 84/88/91/80 about average for all my lugs, but one front was 97 !!!!
b) after retorque to specs, Yaris is smooth as butter when braking
c) gorilla-tech method is always fine for my 4runner, but that thing has
much bigger rotors.
conclusion: you change tires on this little Yaris, torque wrench really is
a requirement. 'Just freaking tight' is going to be overkill on weeny rotors
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-12-2011, 04:10 PM   #2
RedRide
RedRide's Avatar
You have to be careful to tighen the nuts properly no matter if you use a torque wrench or not.
Old 12-12-2011, 04:21 PM   #3
A-Dingo-Ate-My-Baby
Drives: yaris
well I did do it 'properly', but overtorqued one 'cuz I didn't have a
tool to measure, other than 'gumption
properly means use a torque wrench, so this statement doesn't make sense
Old 12-13-2011, 06:33 AM   #4
TOUGEghost
Mr. Clean
TOUGEghost's Avatar
Drives: 2009 Yaris S 3-Door
"Properly" as in "tightening the lugs in the correct sequence." (Not saying you did it wrong, just pointing that out.)
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
Persuade me to buy a Yaris! TONIZZLE General Yaris / Vitz Discussion 48 09-09-2011 11:31 AM
