Old 06-13-2012, 10:47 AM   #1
jp_costarica
Drives: Yaris sedan 2007
LOW RPM @Idle speed = Bad Volt Generation?
Hi, I am having troubles with Bat charging. I have 2 weeks driving with 10.8 to 11.5 volts (~70-80% Battery level). I chech my alternator and its working rarely, in some times at low rpm lights start blinking (high ripple voltage). But also, I have noticed Low RPM when car is at idle speed (~400 - 600rpm) are this normal? Anyone knows what is the minimun rpm alternator, to supply 13.8V? Thanks, /jp
jp_costarica is offline   Reply With Quote
Old 06-13-2012, 11:20 AM   #2
bronsin
bronsin's Avatar
I think an alternator pretty much put out 13-14 v even at idle.
Can you have your battery tested under load at a shop?
Old 06-13-2012, 11:40 AM   #3
ViosFan
Id try and get your battery tested, I think i saw something saying Auto Zone does free battery testing.
ViosFan is offline   Reply With Quote
Old 06-14-2012, 02:44 PM   #4
jp_costarica
Hi All,
I applied the Batt's Garantee, but still with my doubt. I'll have to wait time to probe this, because I have no time to do more testing.
Check this:
-At iddle speed, voltage on batt terminal is 13.5 (same value adding A/A and lights)
-At 2000-5000 rpm, voltage ups to 13.7
Anyone have anysimilar conditions?.m Are this paramethers inside normal operation?
My alternator is a NM toyota Denso.
thanks any RE:
/jp
Old 06-14-2012, 04:56 PM   #5
09sedan
Drives: 2009 yaris sedan
Your alternator output is a bit low, try replacing with a new battery and check your ground connections, if that doesnt help replace alternator.
09sedan is offline   Reply With Quote
alternator, battery, low revs
Low RPM when Idle Betrivent DIY / Maintenance / Service 12 03-03-2013 06:55 PM
driving on Low RPM henry33 DIY / Maintenance / Service 25 09-09-2010 12:59 PM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 04:35 PM
Yaris is low enough stock....trd springs bad??? Yawesh General Yaris / Vitz Discussion 13 12-26-2008 12:17 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 08:41 PM
