08-06-2012, 09:44 PM | #1 |
Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Anyone taken off the intake resonantor tube?
Just wondering if anyone's done that? Has a nice little growl to it when under throttle :)
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
08-07-2012, 02:08 AM | #2 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
I'll bet there are a few people here who have done that...
When I ran my air box, I put a little velocity stack on it just for some bling... One guy even flipped the whole box upside down and trimmed off the bottom so that the filter was completely open and facing up. |
09-11-2012, 06:41 PM | #3 |
Drives: 07 yaris hatch Join Date: Jan 2011
I have a scangaugeII and I drove the car to get a baseline reading for the intake temp... it stayed around 70 degrees. Then i pulled over and removed that piece and drove again the same route and the intake temp rose to about 90 degrees. The sound was awesome without it but its sucking in much hotter air since the inlet is right behind the radiator.
09-11-2012, 07:26 PM | #4 |
Would you guess you'd get better mileage as a result of the warmer air temp?
09-12-2012, 11:54 AM | #5 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
mine has been off for a long time...during the winter i hook up a duct to the airbox that draws air from right off the exhaust manifold (well, its a header now) for better mileage
the only real restriction in the stock intake is the carbon filter...which i promptly removed a few days after i bought the car
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
09-12-2012, 04:18 PM | #6 |
Carbon filter?
09-12-2012, 04:26 PM | #7 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
It's in the "lid" of the air box, IIRC.
09-12-2012, 05:48 PM | #8 |
What does that thing do? Is that the one that's in the white "netting"?
09-12-2012, 07:40 PM | #9 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
It's a required item, part of the emissions control as well as "safety". As far as I know, it's illegal in most (if not all) states to tamper with it. That said, "any" restriction of the airflow will decrease engine output. =)
09-12-2012, 08:49 PM | #10 |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
i saw all of it as a waste and just put on a CAI instead :trollface:
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
09-12-2012, 09:38 PM | #11 |
Obsessed with 1.5L
Its there to neutralize the vapors that emit back out of the combustion chamber after the motor is turned off.
09-12-2012, 10:13 PM | #12 |
Anyone have a picture of it?
09-13-2012, 07:04 AM | #13 |
Similar Threads | ||||
DIY: Intake Installation | redyaris | DIY / Maintenance / Service | 53 | 08-23-2014 05:34 AM |
tooter's manifold adventure... | tooter | Performance Modifications | 1465 | 07-31-2014 08:11 PM |
Weapon R Dragon Intake | yaris2010RS | Items for Sale by private party | 4 | 02-22-2012 03:05 PM |
The great intake debate! | fmicle | General Yaris / Vitz Discussion | 74 | 10-06-2009 11:37 PM |
Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
