11-18-2012, 03:45 PM | #1 |
My Little Blue Egg :)
Drives: '09 3 door Yaris Join Date: Dec 2008
Transmission fluid level
Hello. I am having problems reading my transmission fluid dipstick. Sounds stupid, I know. So the problem is, the fluid level doesn't cover the entire stick. Like it has fluid scattered all over the stick so it's not readable. I had Toyota change the fluid and I'm not sure if its so low to the point that its not readable or if I'm doing something wrong. How should the levels look on a normal reading of the dipstick?
11-18-2012, 06:28 PM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Wipe it, stick it back in, pull it back out, and then read it.
11-28-2012, 05:15 PM | #3 |
I added 1/2 a quart, and then had Toyota look at it and the level was just at the bottom of the notch that said hot. I am guessing that is good enough in terms of enough fluid being in there.
Similar Threads | ||||
How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
So when DOES the transmission fluid need to be changed | dutchy999 | DIY / Maintenance / Service | 12 | 09-06-2011 05:18 PM |
Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
Inception (movie) | Kioshi | Off-topic / Other Cars / Everything else Discussions | 25 | 08-10-2010 02:08 AM |
GET FREE PS3/360/Wii check it out! | marcus | Off-topic / Other Cars / Everything else Discussions | 23 | 09-25-2007 06:51 PM |
