Old 11-21-2012, 04:56 PM   #1
yaris9876
Drives: yaris hatch 07 640K original m
2007 fuel filter
my 07 with 345K is showing signs that the filter is plugged. Has anyone found an easy way to swap out the fuel Filter???
yaris9876 is offline   Reply With Quote
Old 11-21-2012, 05:25 PM   #2
Remove the rear seat, pop the fuel access cover, disconnect the connector, the fuel line, and the vent line from the top of the tank, unscrew the top of the tank (special spanner tool required), lift the sender unit out, remove the fuel pump assembly from the sender, unclip the filter from the bottom, and clip on the new one.
Old 11-28-2012, 06:44 PM   #3
yaris9876
I have seen that metal plate back there and it is spotwelded on....
Old 11-28-2012, 07:13 PM   #4
No. It is glued on with a black super sticky glue. You simply pry it up and then stick it back down when you are done.
Old 12-03-2012, 06:45 PM   #5
yaris9876
ah ha you wouldnt happen to know the dimension of the spanner would you??
Old 12-03-2012, 08:48 PM   #6
I never measured it while I was in there, but this is what it looks like and what the Toyota SST looks like:
Fuel Efficiency and the Yaris BailOut Fuel Economy Forum 325 05-12-2024 01:43 AM
changing fuel filter yaris9876 DIY / Maintenance / Service 8 10-01-2011 10:03 PM
Dose the yaris have a fuel filter ? Moses DIY / Maintenance / Service 14 01-28-2010 07:25 PM
fuel filter ias205 General Yaris / Vitz Discussion 15 05-14-2007 11:02 AM
