Old 05-13-2013, 02:45 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
CVT drain / refill - Yaris 2007
Hi,
My Yaris sedan has completed about 47,000 kms and I'm planning to replace the CVT fluid in the near future. Do I need to also clean up the filter inside or should a simple drain / refill suffice with removing the drain bolt and the drain tube?
Frankly, speaking I do not want to open up the sump but if it has to be done then will do it as that would entail replacing the gasket, drain tube o-ring etc.
Would appreciate some suggestions/advice from those who have done this.
Thanks
Tyrone
tyrone_yaris is offline   Reply With Quote
Old 05-13-2013, 03:57 AM   #2
unclenefeesa
Da Uncle
Hi,
its nice to see somone with a CVT Yaris.
I thought it only sells in Japan.
is it Sedan or Hatchback? and the engine 1.3 or 1.5?
4WD too?
I might not be of help in changing the oil but I am curious about the Car
unclenefeesa is offline   Reply With Quote
Old 05-13-2013, 04:20 AM   #3
tyrone_yaris
Originally Posted by unclenefeesa View Post
Hi,
4WD too?
Thanks
Yes its available worldwide with different names. Here its called a Belta. Its a Sedan 1.0 L Two wheel drive.
Old 05-13-2013, 05:57 AM   #4
bronsin
bronsin's Avatar
I doubt anyone is this country has ever seen a CVT in a Yaris or knows about changing the oil.
Except CTScott....
Old 05-31-2013, 05:54 PM   #5
eseriestv
Drives: Toyota Vitz 2010
Im also seeking for help.
I cant find the cvt oil or how to check it. My car came from Japan and has Super CVT-i
eseriestv is offline   Reply With Quote
Old 06-01-2013, 04:35 AM   #6
bronsin
bronsin's Avatar
What does the owners manual say to do?
Old 06-02-2013, 03:41 AM   #7
nookandcrannycar
Except CTScott....
^^^^^ This = so likely true, it made me chuckle.
Old 06-02-2013, 07:21 AM   #8
Here's a link to an article that I posted a while back on the Micro Image forum on how to change the fluid in a CVT:
http://www.microimageonline.com/foru...T-Fluid-Change
Old 06-03-2013, 06:07 AM   #9
bronsin
bronsin's Avatar
Until the iQ showed up in the US the CVT, as far as I know, was not offered on a Toyota here.
I wonder how they hold up compared to a regular automatic? On a scooter with a CVT the belt will need changing at intervals that vary with the rider and usage the bike gets.
Old 06-05-2013, 03:09 AM   #10
tyrone_yaris
CTScott, do you need to open up the sump to clean the filter/magnets inside or is a simple fluid change suffiicient as you mentioned in the link above? Car has done about 48,000 kms.
Old 06-06-2013, 01:20 AM   #11
tyrone_yaris
Anyone????
Old 06-06-2013, 06:05 AM   #12
The CVT doesn't have a filter, but it does have magnets on the floor of the pan.
Old 06-06-2013, 06:54 AM   #13
tyrone_yaris
So is there a need to open up the pan or its not necessary as the gaskets are not freely available here. Do the magnets get dirty as such which would require cleaning?
Old 06-06-2013, 06:59 AM   #14
I wouldn't drop the pan just to clean the magnets, if the gasket is not easy to come by. They can hold quite a bit of shavings.
Old 06-06-2013, 07:04 AM   #15
tyrone_yaris
That's good to hear CT Scott. Since I'm doing a flush at 50,000 km and the next will be done at 100,000 km so just wanna make sure that a simple drain refill will be fine and wanted your input as our conditions here are hot and dusty.
Old 06-06-2013, 07:42 AM   #16
tyrone_yaris
CT Scott can you help identify this port
While we're on the subject of the CVT flush for the VItz (K410) transmission, I'm attaching a pic of the port that many have used to refill the CVT fluid. Can you identify this port?
Old 06-06-2013, 09:04 AM   #17
It is under the oval shaped black metal piece in the left picture.
Old 06-06-2013, 09:08 AM   #18
tyrone_yaris
You mean that is the CVT filler port for the IKR FE and not the big bolt that is mentioned in the Micromanage link given below??
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
